Weekly programming
DarkG
- Domoticz version: 4.10076
Re: Weekly programming
Will this work with the lastest beta?
RPi4 Shelly1 Shelly2.5 ESPEasy Tuya Domoticz Beta Dashticz 3.6
syrhus
- Domoticz version: 2021.1
Absolutely, it does.
Do you have a trouble with it?
DarkG
I ask to be safe. My system is good running. And I dont wanna crash it. So I ask before İ try.
But after Update it get lost or? So everytime I Update my System I must Install it again. İ am on Beta Channel
syrhus
As this is not in the master branch, after each updates, you have to modify the DeviceTimersController.js file to add the 3 parts as explained on my github gist.
syrhus
A new version is released on my github.
This is a "ready to branch" version, easier to integrate with existing code.
I improve performance and fix some issues.
WARNING, planning.js is now on www/app/timers folder
DarkG
syrhus
did you delete the application cache of your web browser?
if you press F12 (to open developpement tools) and go to the console tab, you should see an error. Check it and let me know.
DarkG
Here you can seesyrhus wrote: Saturday 22 December 2018 11:53 did you delete the application cache of your web browser?
https://www.bilder-upload.eu/bild-f4c5e ... 9.jpg.html
syrhus
Could you show your DeviceTimersController.js file?
It seems you have something wrong in this fils in the getTimers function.
DarkG
define(['app', 'timers/factories', 'timers/components','timers/planning' ], function (app) {
app.controller('DeviceTimersController', function ($scope, $routeParams, deviceApi, deviceLightApi, deviceRegularTimersApi, deviceSetpointTimersApi, deviceTimerOptions, deviceTimerConfigUtils, utils) {
var vm = this;
var deviceTimers;
var deleteConfirmationMessage = $.t('Are you sure to delete this timers?\n\nThis action can not be undone...');
var clearConfirmationMessage = $.t('Are you sure to delete ALL timers?\n\nThis action can not be undone!');
vm.addTimer = addTimer;
vm.updateTimer = updateTimer;
vm.deleteTimer = utils.confirmDecorator(deleteTimer, deleteConfirmationMessage);
vm.clearTimers = utils.confirmDecorator(clearTimers, clearConfirmationMessage);
init();
function init() {
vm.deviceIdx = $routeParams.id;
vm.selectedTimerIdx = null;
deviceApi.getDeviceInfo(vm.deviceIdx).then(function (device) {
vm.isLoaded = true;
vm.itemName = device.Name;
vm.colorSettingsType = device.SubType;
vm.dimmerType = device.DimmerType;
vm.isDimmer = device.isDimmer();
vm.isSelector = device.isSelector();
vm.isLED = device.isLED();
vm.isCommandSelectionDisabled = vm.isSelector && device.LevelOffHidden;
vm.isSetpointTimers = (device.Type === 'Thermostat' && device.SubType == 'SetPoint') || (device.Type === 'Radiator 1');
vm.levelOptions = [];
deviceTimers = vm.isSetpointTimers
? deviceSetpointTimersApi
: deviceRegularTimersApi;
if (vm.isSelector) {
vm.levelOptions = device.getSelectorLevelOptions();
if (vm.isLED) {
$scope.$watch(function () {
return vm.timerSettings.color + vm.timerSettings.level;
}, setDeviceColor);
if (vm.isDimmer) {
vm.levelOptions = device.getDimmerLevelOptions(1);
if (vm.levelOptions.length > 0) {
vm.timerSettings.level = vm.levelOptions[0].value;
refreshTimers();
vm.typeOptions = deviceTimerOptions.timerTypes;
vm.timerSettings = deviceTimerConfigUtils.getTimerDefaultConfig();
$( document ).trigger( "timersInitialized", [vm, refreshTimers] );//<===Update for Planning
refreshTimers();
function refreshTimers() {
deviceTimers.getTimers(vm.deviceIdx).then(function (items) {
vm.timers = items;
$( document ).trigger( "timersLoaded", [items] );;//<===Update for Planning
function setDeviceColor() {
if (!vm.timerSettings.color || !vm.timerSettings.level) {
return;
deviceLightApi.setColor(
vm.deviceIdx,
vm.timerSettings.color,
function getTimerConfig() {
var utils = deviceTimerConfigUtils;
var config = Object.assign({}, vm.timerSettings);
if (!utils.isDayScheduleApplicable(config.timertype)) {
config.days = 0;
if ([6, 7, 10, 12].includes(config.timertype)) {
config.days = 0x80;
if (utils.isOccurrenceApplicable(config.timertype)) {
config.days = Math.pow(2, config.weekday);
config = Object.assign({}, config, {
date: utils.isDateApplicable(config.timertype) ? config.date : undefined,
mday: utils.isRDaysApplicable(config.timertype) ? config.mday : undefined,
month: utils.isRMonthsApplicable(config.timertype) ? config.month : undefined,
occurence: utils.isOccurrenceApplicable(config.timertype) ? config.occurence : undefined,
weekday: undefined,
color: vm.isLED ? config.color : undefined,
tvalue: vm.isSetpointTimers ? config.tvalue : undefined,
command: vm.isSetpointTimers ? undefined : config.command,
randomness: vm.isSetpointTimers ? undefined : config.randomness
var error = deviceTimerConfigUtils.getTimerConfigErrors(config);
if (error) {
ShowNotify(error, 2500, true);
return false;
var warning = deviceTimerConfigUtils.getTimerConfigWarnings(config);
if (warning) {
return config;
function addTimer() {
const config = getTimerConfig();
if (!config) {
return false;
deviceTimers
.addTimer(vm.deviceIdx, config)
.then(refreshTimers)
.catch(function () {
HideNotify();
ShowNotify($.t('Problem adding timer!'), 2500, true);
function updateTimer(timerIdx) {
if (!config) {
return false;
deviceTimers
.updateTimer(timerIdx, config)
HideNotify();
ShowNotify($.t('Problem updating timer!'), 2500, true);
function deleteTimer(timerIdx) {
return deviceTimers.deleteTimer(timerIdx)
HideNotify();
ShowNotify($.t('Problem deleting timer!'), 2500, true);
function clearTimers() {
return deviceTimers
.clearTimers(vm.deviceIdx)
HideNotify();
ShowNotify($.t('Problem clearing timers!'), 2500, true);
syrhus
Please, check what you have modified, you wrote the wrong for the first trigger:
define(['app', 'timers/factories', 'timers/components','timers/planning'], function (app) {
var vm = this;
var deviceTimers;
init();
function init() {
vm.isLoaded = true;
if (vm.isLED) {
}, setDeviceColor);
if (vm.isDimmer) {
refreshTimers();
vm.timers = items;
return;
vm.deviceIdx,
config.days = 0;
config.days = 0x80;
weekday: undefined,
if (error) {
return false;
if (warning) {
return config;
if (!config) {
return false;
deviceTimers
HideNotify();
if (!config) {
return false;
deviceTimers
HideNotify();
HideNotify();
return deviceTimers
HideNotify();
DarkG
syrhus
I changed the previous post to set the entire DeviceTimersController.js file
Please replace it with your one and keep in mind that each time you change a js file, you have to clear your application cache to reload the updated files.
ocean123
I add the script to Domoticz version 4.10717.
And its not working. After restart also not.
No error, no changes, nothing happens.
ocean123
It has something to do with Safari.
Chrome is working fine, Private browsing in Safari also working fine.
But normale browsing in safari, the scheduler is not showing up.
ocean123
salopette
- Domoticz version: BETA
salopette wrote: Sunday 28 July 2019 9:36 @ syrhus
can you do PR for Domoticz?
https://github.com/domoticz/domoticz/is ... -515738984
