If I try to do that it says the folder already exists. Just delete and git clone after that?safi78 wrote:yes. with the new settings window your settings will be stored for future updates.Maikie wrote:For my information, updating just by cloning from git again with this command?
git clone https://github.com/safi78/framb0ise
framb0ise v2 - awesome new dashboard!
Maikie
Re: framb0ise v2 - awesome new dashboard!
safi78
- Domoticz version: LastBeta
That would work. Settings are stored in localstorage, so 0-config after thatMaikie wrote:If I try to do that it says the folder already exists. Just delete and git clone after that?safi78 wrote:yes. with the new settings window your settings will be stored for future updates.Maikie wrote:For my information, updating just by cloning from git again with this command?
homebridge, rfxcom, zwave, nest, applamp, hue, debian, apple, mysensors, netatmo, fibaro, synology, foscam, otherz
Maikie
New version looks really good! The presence info is now correct and the temperature/humidity is now also visibile instead of dry/comfortable
safi78
check out the even newer versionMaikie wrote:New version looks really good! The presence info is now correct and the temperature/humidity is now also visibile instead of dry/comfortable
Maikie
I updated right before I posted, a new version again? Make some update functionality through the config window?safi78 wrote:check out the even newer versionMaikie wrote:New version looks really good! The presence info is now correct and the temperature/humidity is now also visibile instead of dry/comfortable
DennisD
Thx Safi for the latest update. 1 thing i noticed tho, I can't change the panel color. Whenever is choose a different color then grey and i hit save changes it just loads the default color and the dropdown will just say grey. Probally a permissions thing from my side, but just checking.
1 feature request, can you add camera images? Not to sure if this is possible but would be a great feature (in my eyes).
safi78
Just pushed an update for a default class, if it's not set. I can't reproduce this though, old browser? It uses 'localstorage' pretty straightforward to save the settings. Works fine on 'all my devices', anyway, pretty blue is default nowDennisD wrote:Thx Safi for the latest update. 1 thing i noticed tho, I can't change the panel color. Whenever is choose a different color then grey and i hit save changes it just loads the default color and the dropdown will just say grey. Probally a permissions thing from my side, but just checking.
For the feature request, please submit them to: https://github.com/safi78/framb0ise/issues. That way we can keep track of things and multiple people could work on this
I like the idea of camera stuff +1!
andi216
- Domoticz version: 3.7243
Is it possible to add the camera to settings?
- camera1.jpg (79.29 KiB) Viewed 3772 times
- jvdz
- Domoticz version: 4.107
I would think/hope that this project doesn't change into a domoticz of its own but rather be a different view of what is defined in Domoticz Rooms already.
Just my 2 cents
Jos
Just my 2 cents
Jos
qwerk
jvdz wrote:I would think/hope that this project doesn't change into a domoticz of its own but rather be a different view of what is defined in Domoticz Rooms already.
Just my 2 cents
Jos
I agree with Jos.
I also tought Framb0ise was a simple but complete way to show/use domoticz.
every add-on makes it more dashticz like or domoticz itself.
I'm pleased with every add-on but I'm also a bit scared of making it to big and difficult.
ZERO CONFIG, a config window will popup after installation: will fade away.
Sander, keep up the good work, I really like Framb0ise, but I think, simple is the key.
- jvdz
Made a commit this evening that gets close to thisqwerk wrote: ZERO CONFIG, a config window will popup after installation: will fade away..
Jos
robgeerts
- Domoticz version: 3.7067
Thanks, I take this as a complimentqwerk wrote: every add-on makes it more dashticz like or domoticz itself.
Maikie
Í noticed another change in the last update.
The power meter is not only showing total now, but showing current and total of this day.
Perhaps this is also possible for the other meters?
CaesarPL
Good evening,
Is Calendar plugin working already? I've provided proper public profile and the fieldset is empty,
safi78
robgeerts wrote:Thanks, I take this as a complimentqwerk wrote: every add-on makes it more dashticz like or domoticz itself.
safi78
Sure, can you show me the json?Maikie wrote:Í noticed another change in the last update.
safi78
Yes that is possibleandi216 wrote:Is it possible to add the camera to settings?
Added in the new version.
Camera's have to be defined, setup & working in domoticz
safi78
I tested this with a public ics from a gmail account, works like a charm.CaesarPL wrote:Good evening,
Can I see your ics? (in a PM perhaps?)
tontze
- Domoticz version: Beta Ch
Yes, thats correct, it has stop button.jvdz wrote:@tontze ,
Am I correct to assume that this blind doesn't have an percentage option, but merely UP/DOWN ( and possibly STOP)?
Jos
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
- jvdz
Just create a feature request in GITHUB for supporting this device as currently there is no support for these type of blinds so needs to be added.
Jos
Jos
Users browsing this forum: FireWizard and 1 guest
