framb0ise v2 - awesome new dashboard!
Maikie
Re: framb0ise v2 - awesome new dashboard!
Post by Maikie »
safi78 wrote:
Maikie wrote:For my information, updating just by cloning from git again with this command?
git clone https://github.com/safi78/framb0ise
yes. with the new settings window your settings will be stored for future updates.
If I try to do that it says the folder already exists. Just delete and git clone after that?
safi78
Domoticz version: LastBeta
Post by safi78 »
That would work. Settings are stored in localstorage, so 0-config after that :)
homebridge, rfxcom, zwave, nest, applamp, hue, debian, apple, mysensors, netatmo, fibaro, synology, foscam, otherz
Maikie
Post by Maikie »
New version looks really good! The presence info is now correct and the temperature/humidity is now also visibile instead of dry/comfortable
safi78
Post by safi78 »
Maikie wrote:New version looks really good! The presence info is now correct and the temperature/humidity is now also visibile instead of dry/comfortable
check out the even newer version ;)
Maikie
Post by Maikie »
I updated right before I posted, a new version again? Make some update functionality through the config window?
DennisD
Post by DennisD »
Thx Safi for the latest update. 1 thing i noticed tho, I can't change the panel color. Whenever is choose a different color then grey and i hit save changes it just loads the default color and the dropdown will just say grey. Probally a permissions thing from my side, but just checking.
1 feature request, can you add camera images? Not to sure if this is possible but would be a great feature (in my eyes).
safi78
Post by safi78 »
DennisD wrote:Thx Safi for the latest update. 1 thing i noticed tho, I can't change the panel color. Whenever is choose a different color then grey and i hit save changes it just loads the default color and the dropdown will just say grey. Probally a permissions thing from my side, but just checking.
Just pushed an update for a default class, if it's not set. I can't reproduce this though, old browser? It uses 'localstorage' pretty straightforward to save the settings. Works fine on 'all my devices', anyway, pretty blue is default now ;)
For the feature request, please submit them to: https://github.com/safi78/framb0ise/issues. That way we can keep track of things and multiple people could work on this :)
I like the idea of camera stuff +1!
andi216
Domoticz version: 3.7243
Post by andi216 »
Is it possible to add the camera to settings?
jvdz
Domoticz version: 4.107
Post by jvdz »
I would think/hope that this project doesn't change into a domoticz of its own but rather be a different view of what is defined in Domoticz Rooms already.
Just my 2 cents ;-)
Jos
qwerk
Post by qwerk »
jvdz wrote:I would think/hope that this project doesn't change into a domoticz of its own but rather be a different view of what is defined in Domoticz Rooms already.
Just my 2 cents ;-)
Jos
I agree with Jos.
I also tought Framb0ise was a simple but complete way to show/use domoticz.
every add-on makes it more dashticz like or domoticz itself.
I'm pleased with every add-on but I'm also a bit scared of making it to big and difficult.
ZERO CONFIG, a config window will popup after installation: will fade away.
Sander, keep up the good work, I really like Framb0ise, but I think, simple is the key.
jvdz
Post by jvdz »
qwerk wrote: ZERO CONFIG, a config window will popup after installation: will fade away..
Made a commit this evening that gets close to this :)
Jos
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
qwerk wrote: every add-on makes it more dashticz like or domoticz itself.
Thanks, I take this as a compliment :)
Maikie
Post by Maikie »
Í noticed another change in the last update.
The power meter is not only showing total now, but showing current and total of this day.
Perhaps this is also possible for the other meters?
CaesarPL
Post by CaesarPL »
Good evening,
Is Calendar plugin working already? I've provided proper public profile and the fieldset is empty,
safi78
Post by safi78 »
:lol:
safi78
Post by safi78 »
Maikie wrote:Í noticed another change in the last update.
Sure, can you show me the json?
safi78
Post by safi78 »
andi216 wrote:Is it possible to add the camera to settings?
Yes that is possible :)
Added in the new version.
Camera's have to be defined, setup & working in domoticz :D
safi78
Post by safi78 »
CaesarPL wrote:Good evening,
I tested this with a public ics from a gmail account, works like a charm.
Can I see your ics? (in a PM perhaps?)
tontze
Domoticz version: Beta Ch
Post by tontze »
jvdz wrote:@tontze ,
Am I correct to assume that this blind doesn't have an percentage option, but merely UP/DOWN ( and possibly STOP)?
Jos
Yes, thats correct, it has stop button.
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
jvdz
Post by jvdz »
Just create a feature request in GITHUB for supporting this device as currently there is no support for these type of blinds so needs to be added.
Jos
