I'm using mdah for a long time, it perfectly works
I have version 0.1.51, but I can't succeed in installing lastest version 0.1.57 :
- I tried "sudo apt-get update" then "sudo apt-get upgrade" then "sudo apt-get dist-upgrade", but still 0.1.51
- I uninstalled mdah then reinstalled it, and apt-get still find 0.1.51.
what am I going wrong?
I have a pi2 with jessie, I have the good e-nef source in sources.list..
Have you any idea to help me? thank you
VM Debian - Domoticz stable v2025.2, RFXtrx433, Aeotec Z-Stick Gen5, Zigbee, Two APC
- rts: dio, oregon, somfy
- zwave: fibaro fgs212, aeotec smart switch, vision ZG8101
- IO Homecontrol: Velux Connexoon
- philips hue, Pilot app.
i followed the guide, and see my devices with ip:port booth gateway and domoticz but in the app it doesn´t show the devices or anything. i get "ISS system success"
Its probably allready answered but i dint find it back in the forum or wiki (maybe handy to add it in the wiki)
my setup:
Domoticz and imperhome are working fine (without users/passwords)
now i wanted to add users and passwords in my domoticz system but now i cant get the app imperihome working anymore..
do i need to do something more then just fill in the 'admin' and 'passsword' field in the configuration wizard in the app?
(so without any sort of authentification (blank password and user) was it all working fine, now i added some users and i cant get imperihome working anymore.. )
is it not possible to use imperihome with different domoticz users?
gilzin wrote:when i try to activate my camera from imperihome i am getting "unable to read stream error"
the camera works fine from domoticz app
can some one knows why?
please use native camera support from imperihome, imperihome is not good on the flow from domoticz
DRuw wrote:Hi guys, I have an issue with the graphs and data of the energy meters.
Ive got all things running (see previous posts in this topic) and since last week I have installed solar panels.
Domoticz show a negative number when I produce more energy than I consume and also in the webinterface I have 4 graphs: use high rate, use low rate and proction high an low.
In domoticz this work perfect and looks great but in the mobile interface of imperihome it all goes south...
It seems that only consumption is used and the production isnt?
Can this be changed???? (should be, Domotics is correct...)
yes if you guide me through which data to expose from API
mvzut wrote:I also have issues with the new MyDomoAtHome. I completely re-installed my Raspberry Pi 2B with a fresh install of Domoticz etc. But then I found out that this the new Javascript implementation has two MAJOR drawbacks on my system:
My Raspberry Pi uses around 10% cpu when Imperihome is running. This used to be around 3%.
Loading graphs takes ages! From a few seconds with the "old" version to >10 seconds now
Are these aspects that are still being worked on? Or do I just have to live with them, or switch over to a faster system?
P.S. I don't have the problems that ripp2003 describes, operating switches etc. is almost instantaneous
Should not, for I've had better perf with the latter, have you installed a recent nodejs as on the doc ?
But when I try to search the devices on iOS Ididn't find any device, instead if I try on android I see only a sensor called mydomeathome.
Do you have any suggestion?
Luca
Exactly same same problem here with fresh install of MDAH.
Everything seems to work in the URL but won't work in the ImperiHome (lite) app, with same thing, I can see only one sensor called MyDomoAtHome.
Any clue?
Still have the same issue ? try reload (top right menu) sometimes there is a little latency on first use
I have a problem with MyDomoAtHome as the REST interface between the Domoticz and Imperihome.
That is, a gas consumption meter in "utilities" tab of Domoticz is not shown with the "graph" option enabled in Imperihome.
There are though some other temperature sensors which have this option "graph" enabled.
How can we tackle the issue?
Please note that sharing the whole database is not a good idea, maybe we can start differently with some other data/output which could help? Below, I will provide the JSON output of Domoticz for the gas meter which casuses the problem.
Thanks for any ideas in advance,
Hanry.
The JSON output:
P.S. here is the JSON output for the Gas Meter which is not enabled with the "graphs" option:
ok looks like I did not say it was graphable, easy to correct.
"Please note that sharing the whole database is not a good idea": gizmocuz do it and recommanded me to do it too so it is one proposal, for graphs this is where I need it when values are strange... for graphing is based on live data, and I cannot fake
