"If watts" dont work? (blockly)
Evelen
Domoticz version: 2.4538
Post by Evelen »
Ok.
Why don't this work?
IF watt-utilety < 5
Set dummy-button = on
when the watts is above 5 nothing happening, when the watts is under 5 nothing happening.
why?
This is shat I want to do:
If the watts is above a value (5) a dummy should go to "on"
When det watt is under a value (4) for 10 minutes set dummy to "off".
Is this posible?
Uten navn.png (23.21 KiB) Viewed 2122 times
Derik
Re: "If watts" dont work? (blockly)
Post by Derik »
please share the print of the blockley..
Evelen
Post by Evelen »
Here it is:
Uten navn.png (14.92 KiB) Viewed 2106 times
Derik
Post by Derik »
u have to use mutiple options with this type of blockley. [ use the other or make more blockleys with the button ]
Then you have check in your blockley, if vaskemaskin = off ,after x you want, set vaskemaskin on
Evelen
Post by Evelen »
ohh, okey, worked (Y)
now, how do i set "if watts is below 4 for 10 minutes"
Derik
Post by Derik »
Evelen wrote:ohh, okey, worked (Y)
Unfortunly not possible with a blockley
Hope this option will be available sometime...
Perhaps you can make a dummy switch that is counting ...
Evelen
Post by Evelen »
hmmm.
maybe this will work?
Uten navn.png (56.43 KiB) Viewed 2006 times
Derik
Post by Derik »
Evelen wrote:hmmm.
I hope
Let me now...
I need some counters in blockley to..
Evelen
Post by Evelen »
I will.
don't work yet: viewtopic.php?f=6&t=13499
Evelen
Post by Evelen »
Evelen wrote:I will.
^ this is now fixed after update to newest beta.
Now, this turn on the dummy at 300W+, but never turns it down, the variable is set to "not_running", but the dummy (vaskemaskin) is still on and never goes off
Uten navn.png (43.22 KiB) Viewed 1935 times
booster
Post by booster »
changing a uservariable via an event will not trigger the eventsystem, therefore your latest else-if will not occur.
But why using a user variable at all? (I dont see its benefit from your blockly)
why not switching Vaskemaskin itself off after 120 secs?
Connected to:
-Pi3; Aeon Labs Z-Stick; Fibaro Switches, Roller Shutter and Motion Sensors; Qubino Dimmers; P1 Port + Youless, MiLight; HUE Bridge; Forest shuttle Z-Wave; RFLink + KAKU; Voltcraft CO20; Everspring floodsensors; GreenWave PN-6; NEO Sensors
