MyDomoticz - Testers wanted!
deejc
Domoticz version: 3.5641
Re: Testers wanted!
Post by deejc »
good news.
Domoticz 3.5641 on RPI (Raspbian GNU/Linux 8)
mikejclark
Re: Testers wanted!
Post by mikejclark »
Hi, just registered for the service, but I don't get an instance id - just says (none) - and this is in the log:
Error: PROXY: StartThread(): Exception: close: Bad file descriptor
Edit
And now this:
Error: PROXY: Connect failed, reconnecting: Network is unreachable
Syssy
Domoticz version: 3.0.5683
Re: Testers wanted!
Post by Syssy »
mikejclark wrote:Hi, just registered for the service, but I don't get an instance id - just says (none) - and this is in the log:
Edit
And now this:
Same for me.
How we could solve that ?
Syssy
Re: Testers wanted!
Post by Syssy »
Edit
And now this:
Same for me.
Solved with Domoticz v3.0.5683-7 for DSM6 !
Great !
Syssy
Re: Testers wanted!
Post by Syssy »
New try :
https://my.domoticz.com/mydomoticz/logi ... itchcmd=On"
Respond :
"success" : 1.0,
"usermessage" : "OK"
But nothing append on my local domoticz log...
Do you have any idea to do that for IFTT ?
chimit
Domoticz version: master
Re: Testers wanted!
Post by chimit »
Syssy wrote:New try :
Respond :
"success" : 1.0,
IFTT support will probably be added during/after app support (with OAUTH).
Currently there's no target date known of when that will be finished.
flabrosse
Re: Testers wanted!
Post by flabrosse »
Trying mydomoticz, which sounds like a great idea. I have registered and got an instance ID. When I login on mydomoticz, it clearly gives me something, but only the "green man". Clicking on any of the links just returns me to that page (apart from the settings page).
Just a bit of feedback and perhaps a question as to whether I missed something.
Great idea anyway. I hope to be able to use it at some point as I am progressing in the automation of my house.
Cheers,
Fred
chimit
Re: Testers wanted!
Post by chimit »
flabrosse wrote:Trying mydomoticz, which sounds like a great idea. I have registered and got an instance ID. When I login on mydomoticz, it clearly gives me something, but only the "green man". Clicking on any of the links just returns me to that page (apart from the settings page).
Cheers,
Fred
Just click right on the green man. And you're in.
flabrosse
Re: Testers wanted!
Post by flabrosse »
Right click? That brings up the contextual menu of my browser. Left clicking just brings me back to the green man.
chimit
Re: Testers wanted!
Post by chimit »
flabrosse wrote:Right click? That brings up the contextual menu of my browser. Left clicking just brings me back to the green man.
Left click should do. Try it a couple of times. And if that works, the following question is: Do you have login page authentication enabled?
Madgeni
Re: Testers wanted!
Post by Madgeni »
+1 for oauth2 support! Any idea on timescales?
flabrosse
Re: Testers wanted!
Post by flabrosse »
I have tried clicking many times and I always end up on the green man. I'm not sure what you mean by page authentication enabled. I've had to login by giving my uid and password.
juankar
Domoticz version: 4.
Re: Testers wanted!
Post by juankar »
Can not recover my password. I click "forgot password", write my email and receive a link but when the link drive to the login page and the message "this link has expired" appears.... so I can't recover my pass. :(
darlomrh
Re: Testers wanted!
Post by darlomrh »
I was also getting the proxy errors. Removed instance and updated the password on mydomoticz and in settings on domoticz. When I log into mydomoticz now I'm met with a blank dashboard page and nowhere to add the instance back in.
Any ideas?
chimit
Re: Testers wanted!
Post by chimit »
darlomrh wrote:I was also getting the proxy errors. Removed instance and updated the password on mydomoticz and in settings on domoticz. When I log into mydomoticz now I'm met with a blank dashboard page and nowhere to add the instance back in.
Any ideas?
What do you domoticz log files say, when trying to connect to mydomoticz?
chimit
Re: Testers wanted!
Post by chimit »
juankar wrote:Can not recover my password. I click "forgot password", write my email and receive a link but when the link drive to the login page and the message "this link has expired" appears.... so I can't recover my pass. :(
I just tested the send password link once again. It works for me.
Note: Only the last link that was sent will work.
chimit
Re: Testers wanted!
Post by chimit »
Any ideas?
Could you pm me your email address or api key?
chimit
Re: Testers wanted!
Post by chimit »
The short answer: No. It depends on whenever I have enough free time available for implementation and testing.
juankar
Re: Testers wanted!
Post by juankar »
Solved.
juankar
Re: Testers wanted!
Post by juankar »
Hi again
Now I can get mydomoticz but I can't access my dashboard: man icon is red
In log I get
2016-09-30 11:36:28.333 Proxymanager started.
2016-09-30 11:36:28.536 Active notification subsystems: http (1/11)
2016-09-30 11:37:43.339 Error: PROXY: timeout occurred, reconnecting
An then a lot of messages:
2016-09-30 11:37:58.389 Error: PROXY: Connect failed, reconnecting: Network is unreachable
Domoticz version 3.5478
Users browsing this forum: Varazir and 1 guest
