MyDomoticz - Testers wanted!
Re: Testers wanted!
Hi, just registered for the service, but I don't get an instance id - just says (none) - and this is in the log:
Error: PROXY: StartThread(): Exception: close: Bad file descriptor
Edit
And now this:
Error: PROXY: Connect failed, reconnecting: Network is unreachable
Edit
And now this:
- Domoticz version: 3.0.5683
Re: Testers wanted!
Same for me.mikejclark wrote:Hi, just registered for the service, but I don't get an instance id - just says (none) - and this is in the log:
Edit
And now this:
How we could solve that ?
Re: Testers wanted!
Solved with Domoticz v3.0.5683-7 for DSM6 !Syssy wrote:Same for me.mikejclark wrote:Hi, just registered for the service, but I don't get an instance id - just says (none) - and this is in the log:
Edit
And now this:
Great !
Re: Testers wanted!
New try :
https://my.domoticz.com/mydomoticz/logi ... itchcmd=On"
Respond :
"success" : 1.0,
"usermessage" : "OK"
But nothing append on my local domoticz log...
Do you have any idea to do that for IFTT ?
Respond :
"success" : 1.0,
- chimit
- Domoticz version: master
Re: Testers wanted!
IFTT support will probably be added during/after app support (with OAUTH).Syssy wrote:New try :
Respond :
"success" : 1.0,
Currently there's no target date known of when that will be finished.
Re: Testers wanted!
Trying mydomoticz, which sounds like a great idea. I have registered and got an instance ID. When I login on mydomoticz, it clearly gives me something, but only the "green man". Clicking on any of the links just returns me to that page (apart from the settings page).
Just a bit of feedback and perhaps a question as to whether I missed something.
Great idea anyway. I hope to be able to use it at some point as I am progressing in the automation of my house.
Cheers,
Fred
Cheers,
Fred
- chimit
Re: Testers wanted!
Just click right on the green man. And you're in.flabrosse wrote:Trying mydomoticz, which sounds like a great idea. I have registered and got an instance ID. When I login on mydomoticz, it clearly gives me something, but only the "green man". Clicking on any of the links just returns me to that page (apart from the settings page).
Cheers,
Fred
Re: Testers wanted!
Right click? That brings up the contextual menu of my browser. Left clicking just brings me back to the green man.
- chimit
Re: Testers wanted!
Left click should do. Try it a couple of times. And if that works, the following question is: Do you have login page authentication enabled?flabrosse wrote:Right click? That brings up the contextual menu of my browser. Left clicking just brings me back to the green man.
Re: Testers wanted!
+1 for oauth2 support! Any idea on timescales?
Re: Testers wanted!
I have tried clicking many times and I always end up on the green man. I'm not sure what you mean by page authentication enabled. I've had to login by giving my uid and password.chimit wrote:Left click should do. Try it a couple of times. And if that works, the following question is: Do you have login page authentication enabled?flabrosse wrote:Right click? That brings up the contextual menu of my browser. Left clicking just brings me back to the green man.
- Domoticz version: 4.
Re: Testers wanted!
Can not recover my password. I click "forgot password", write my email and receive a link but when the link drive to the login page and the message "this link has expired" appears.... so I can't recover my pass.
- darlomrh
Re: Testers wanted!
I was also getting the proxy errors. Removed instance and updated the password on mydomoticz and in settings on domoticz. When I log into mydomoticz now I'm met with a blank dashboard page and nowhere to add the instance back in.
Any ideas?
Any ideas?
- chimit
Re: Testers wanted!
What do you domoticz log files say, when trying to connect to mydomoticz?darlomrh wrote:I was also getting the proxy errors. Removed instance and updated the password on mydomoticz and in settings on domoticz. When I log into mydomoticz now I'm met with a blank dashboard page and nowhere to add the instance back in.
Any ideas?
- chimit
Re: Testers wanted!
I just tested the send password link once again. It works for me.juankar wrote:Can not recover my password. I click "forgot password", write my email and receive a link but when the link drive to the login page and the message "this link has expired" appears.... so I can't recover my pass.
Note: Only the last link that was sent will work.
- chimit
Re: Testers wanted!
Could you pm me your email address or api key?darlomrh wrote:I was also getting the proxy errors. Removed instance and updated the password on mydomoticz and in settings on domoticz. When I log into mydomoticz now I'm met with a blank dashboard page and nowhere to add the instance back in.
Any ideas?
- chimit
Re: Testers wanted!
The short answer: No. It depends on whenever I have enough free time available for implementation and testing.Madgeni wrote:
Re: Testers wanted!
Solved.chimit wrote:I just tested the send password link once again. It works for me.juankar wrote:Can not recover my password. I click "forgot password", write my email and receive a link but when the link drive to the login page and the message "this link has expired" appears.... so I can't recover my pass.
Re: Testers wanted!
Hi again
Now I can get mydomoticz but I can't access my dashboard: man icon is red
In log I get
2016-09-30 11:36:28.333 Proxymanager started.
2016-09-30 11:36:28.536 Active notification subsystems: http (1/11)
2016-09-30 11:37:43.339 Error: PROXY: timeout occurred, reconnecting
An then a lot of messages:
2016-09-30 11:37:58.389 Error: PROXY: Connect failed, reconnecting: Network is unreachable
Domoticz version 3.5478
In log I get
Users browsing this forum: Google [Bot] and 0 guests
