raspberry usb connection died with rfxcom
tiga
Post by tiga »
i have a big problem.
im using the starter set of sos-solutions (raspberry rfxcom and so on) for about a year now with no problems.
but when i came back from work i descovered that my system did not work anymore.
the rfxcom's red light is flashing continously.....but when connected to the rfxmngr on my laptop it works fine.
last night i saw in the log files some error with the usb.
in the hardware section in domoticz the rfxcom is still there but with no Seriële poort i can choose.the active box is not checked anymore but that does not change a thing.
all the wireless devices are gone in domoticz :(
so what i have tried is:
-connect rfxcom to laptop-->works fine
-replaced the software on the sd card of the raspberry with a backup i made-->same result
-tried a different power supply on the raspberry-->same result
-i googled how to check the raspberry's usb ports (with putty)and came up with this command : lsusb -t
this is the result:
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=dwc_otg/1p, 480M
|__ Port 1: Dev 2, If 0, Class=hub, Driver=hub/5p, 480M
|__ Port 1: Dev 3, If 0, Class=vend., Driver=smsc95xx, 480M
according to the site this means there is nothing connected to the raspberry.....
can i solve this problem and how?????
and how can it die suddenly??
SweetPants
Re: raspberry usb connection died with rfxcom
Post by SweetPants »
Sure you have a 2A or more Power Supply and a decent USB cable?
Over time cheap psu's tent to wear down giving all kinds of problems.
tiga
Post by tiga »
I ordered the complete set with Power supply.it would be strange that you Have to change them every year.i can test it with 3rd one.
tiga
Post by tiga »
update :D : S.O.S. solutions wants the raspberry send back to them so they can take a look.
thumbs up for good servive!! :D :D
Breezers
Post by Breezers »
Keep us posted if the problem is solved or still existent ?
Some others are having problems to, perhaps any connetcions ? http://www.domoticz.com/forum/viewtopic ... 237#p98237
tiga
Post by tiga »
They got the raspberry Today.i Will Keep you all posted.i buyed a new Power supply (Yes a good quality one of 2amps).but that Made no difference.when i hear from sos solutions i Will post it here.
tiga
Post by tiga »
well......little (useless) update.
got the raspberry back today but without any feedback.no mail or phonecall or letter with the package.so i thought it will be fixed :D
so i connected everything together and tadaaaaaaa!!!!!..........same problem..... :o :?
i send them an email to ask what they done and how we can fix it....again...
so i keep you posted.... ;)
tiga
Post by tiga »
yes!!!! :D :D :D
last time i got the pi back and they said the pi was tested and works fine :o , i tested the rfxcom and it works fine.
so it had to be the combination of the 2 so send the whole set back.
today:raspberry pi and rfxcom in my mailbox!!back from sos solutions.
put it all togheter and it seems to work fine again!
they put a sticker on the device that they mailed me the feedback but i did not received it.
maybe i filled in the wrong email adress.
i asked them to mail it to me again,so maybe tomorrow the feedback from the repair.
but when i connected everything i noticed that the mac-adres is different than my origional raspberry, so i think i got a new raspberry.
everything works fine now :D thanks SOS-Solutions!!!!good service!!!
Users browsing this forum: willemd and 1 guest
