piokuc
Re: Domoticz app 2.0
Post by piokuc »
On your galaxy s7 for you fingerprint works ok ?
Monki77
Re: RE: Re: Domoticz app 2.0
Post by Monki77 »
piokuc wrote:On your galaxy s7 for you fingerprint works ok ?
I don't have the beta app so no option to use fingerprint and try it :(
Sent from my SM-G930F using Tapatalk
Monki77
Post by Monki77 »
Tried the app again after restarting the Pi *just incase*.
Same thing happened... changed the colour of a light in the living room and even though it responded straight away this time - it carried on switching between red and white light until I force closed the app.
Weird =/
piokuc
Post by piokuc »
I ask galadril about fingerprint...
fergalom
Post by fergalom »
mcduarte2000 wrote:
galadril wrote:
mcduarte2000 wrote:How can we make the NFC tags to work?
I can add an NFC tag, I can associate Domoticz app with a switch, the phone recognizes the tag, but no visible action...
The phone just says "New tag collected"...
Update 1: If I write "nl.hnogames.domoticz.premium", I can start the app automatically. Still no action besides that...
Please check my comment here:
viewtopic.php?f=37&t=8884&start=1040#p89135
I did it also, as URL It opens chrome and says "Not Found" "The requested URL /app was not found on this server." As a text it says "New tag collected" "http://www.domoticz.com/app".
My Android is 6.0.1. Maybe related with it?
Has anyone got the NFC feature to work on Android 6? (I have a stock S7)
Both suggestions in this thread do not work:
1. Writing "http://www.domoticz.com/app" to the tag does not work, opens a 404 blank webpage and the app does not pick it up as suggested
2. Writing "nl.hnogames.domoticz.premium" to the tag will open the app but no further action. Tag is registered in domoticz settings, enabled and associated with a switch.
https://drive.google.com/file/d/0BxPSuZ ... sp=sharing
galadril
Domoticz version: latest
Post by galadril »
fergalom wrote: Has anyone got the NFC feature to work on Android 6? (I have a stock S7)
Hi, Sorry if it was not clear on how to configure NFC tags. I've now made a wiki page on github to describe the NFC setup:
https://github.com/domoticz/domoticz-an ... /NFC-Setup
NOTE.. you need to write the NFC with type URL, not text
fergalom
Post by fergalom »
Thanks but had tried both text and url types before.
Installed the NFC app you used to write to the tag, same result
Still opens a webpage and Error 404 - Domoticz app does not pick it up and toggle the switch.
My tag is a standard NXP Mifare Ultralight
galadril
Post by galadril »
fergalom wrote:Thanks but had tried both text and url types before.
I think you've probably selected Chrome as the default app to open URL NFC tags :(
fergalom
Post by fergalom »
Don't think so but did Settings>Apps->Chrome->Clear Defaults and same result.
If I look at Settings>Apps->Domoticz - App links->Supported URLs and Supported Web addresses is blank?
It won't let me edit them however.
wergeld
Post by wergeld »
What happened with the tablet support for Nexus 7 (2012)? It was on there a few months ago but I recently had to wipe this tablet to factory settings. Now Google Play is saying I cannot install this application as it is not compatible with my device. I have tried to install both the full version (and beta) and the light version to no avail. :?:
nnylund
Post by nnylund »
Sorry if this has been asked before.
Would be great if the app could be used to access Domoticz via the MyDomoticz proxy. Any chance for that in the future?
SweetPants
Post by SweetPants »
After using the Lite version for a while, I purchased the Premium version yesterday and I love the voice recognition feature. I don't know if this has been asked before, but are there plans to support voice controlled scene's?
SweetPants
wergeld wrote:What happened with the tablet support for Nexus 7 (2012)?
I have the same problem/question. I can see the Lite version , but with the note 'Je apparaat is niet compatibel met deze versie'.
I run Android 4.4.4 on this Nexus 7 because Lolipop makes the tablet very slow. However, on my HTC Desire 610 that runs Android 4.4.2 Domoticz Lite and Premium works fine. What is the problem here? Would it run if I upgrade the tablet to Lolipop?
galadril
Post by galadril »
No clue at this moment why Nexus 7 is not shown as compatible :(
From the Dev console of Play Store
Android version
4.1 and higher
If anyone likes to assist on this... you can check the manifest on github ..
https://github.com/domoticz/domoticz-an ... evelopment
Timdgr
Post by Timdgr »
I don't think that upgrade to lollipop will make a difference. Mine is running 5.1.1 and i get the same message from google play store.
But it's good to see that i'm not the only one facing this issue with Nexus 7, so it looks that it's not me doing something wrong...
Hope that there will be a solution soon.
SweetPants
galadril wrote:If anyone likes to assist on this... you can check the manifest on github ..
What am I looking for? I'm not an Android app programmer
fergalom
Post by fergalom »
fergalom wrote:Don't think so but did Settings>Apps->Chrome->Clear Defaults and same result.
Any thoughts on this galadril, would like to get this solved
galadril
Post by galadril »
fergalom wrote:Any thoughts on this galadril, would like to get this solved
No not yet.. I've tested this on multiple devices.. all work (nexus 5, 6, 5x.. android 5 and 7)
SweetPants
I was able to get the source code from Github build to an .apk using Android Studio, and guess what, I can install the Lite version on the Nexus 7 (2012) tablet using the manifest in the source code. When installing Lite version from Play Store, same problem 'Je apparaat is niet compatible met deze versie'. When i try to build the Paid version, i get a (paid) .apk, get it installed, but it starts in Lite mode and I can't upgrade (same error)
galadril
Post by galadril »
Does the latest beta still has the Nexus 7 issue ?
I've changed some feature requirements in the manifest...
