Ill look into itNiklasO wrote:Can't control blinds from the widget?
Would like to see "Open" and/or "Close" button..
- galadril
- Domoticz version: latest
Re: Domoticz app 2.0
Domoticz Android app:
https://play.google.com/store/apps/deta ... s.domoticz
- Shaggie_NB
Did PM you but the message stays in my outbox??galadril wrote:Can you create a read-only account for me and PM me de details?Shaggie_NB wrote:I'm still having problems with the graphs from the Gas and CO2 meters (they won't show). For Electricity and Temp they are working OK!
In the Domotictz (website) they are all working fine...
This was already mentioned by me but everybody was so busy with all the new (and great!) functionalities I thougt it would be picked up later.....
So here is my question again...
- galadril
Should be fixed in next beta.Shaggie_NB wrote: Did PM you but the message stays in my outbox??
pollefinario
I've got a Philips 23" android touch screen. At the moment it is not able to install the app. Is this due to the screen resolution being in the config files?
The device is stuck at 4.2.2.
Any possibility to make this device compatible?
Thanks a lot.
Device info:
http://www.philips.nl/c-p/S231C4AFD_00/ ... cificaties
Thanks a lot.
Device info:
- galadril
You can now also modify the user variables values in the next beta
martk
Finally! Tried this a few times already but couldn't. Thanks
roblom
"Zet"?
Verstuurd vanaf mijn HTC One M9 met Tapatalk
- galadril
Big feature in the next beta
Protect the app with your fingerprint
piokuc
Please correct aligment text on dashboard in grid view. Should all text center or alligment to left.
- galadril
They should be centered.. maybe you have something where with your naming..?piokuc wrote:Please correct aligment text on dashboard in grid view. Should all text center or alligment to left.
piokuc
Yes. Some naming is center and is ok but some is not center.. look on my screen.
Example:
TV salon -KWh is ok
But temperatura -"wschód" is not ok.
TV salon -KWh is ok
piokuc
Today i install new beta and alligment is still problem.
Next problem is that option Configuration server download not working. When i click on this it nothing do.
- MarcelMAH
- Domoticz version: v3.8025
I recieved the non beta update yesterday and AGAIN I had to remove my data from the app to be able to use it again (after setting it up again)
Running Domoticz on Ubuntu 16.04 on VMware with RFXCOM - RFXtrx433 and Aeotec Z-Stick Gen5
jannl
- Domoticz version: 2026.1.x
In the new update all settings where gone. Remaining problem is that it is not possible to set the protocol to https (every time I look it is back to http). I do not use the standard https port.
- mlamie
- Domoticz version: 3.5877
The latest update caused an issue which I can not resolve. With version (0.1.316) something changed in the network configuration. Normally I only connect via the local ip (192.168.x.x) and if I'm outside I use openvpn. Can someone help me! P.s. via an internet browser everything works fine.
Raspberry Pi 3, RaZberry, RFXtrx433
Various Z-Wave devices, KlikAanKlikUit devices, ESP8266 NodeMCU, Sonoff POW and a Essent E-thermostaat
IP camera: Dahua 4MP IPC-HDBW4421R-AS, Vivotek FD8134V
- Shaggie_NB
Thanks!!!!galadril wrote:Can you create a read-only account for me and PM me de details?Shaggie_NB wrote:I'm still having problems with the graphs from the Gas and CO2 meters (they won't show). For Electricity and Temp they are working OK!
In te new beta all graphs are working OK.
Keep up the great work!!
So according to that list, it should work if plain Nexus 7 means the original 2012 version...galadril wrote:From the play store device compatibility list:
Unfortunately i can't install it. Too bad that it does not give any clue on why it refuses to install.
I googled around a bit and found some instructions on clearing google play cache and such but didn't help out.
Any ideas?
I'm actually running the Domoticz lite version 0.1.243 app on the very same tablet...
even more strange isn't it? Or have requirements changed since that version?
- mlamie
In the Play store the 4 latest comments did report the same issue after the update. Can someone have a look soonest?mlamie wrote:The latest update caused an issue which I can not resolve. With version (0.1.316) something changed in the network configuration. Normally I only connect via the local ip (192.168.x.x) and if I'm outside I use openvpn. Can someone help me! P.s. via an internet browser everything works fine.
- galadril
Can you create a view-only account for me and pm me the details?mlamie wrote:In the Play store the 4 latest comments did report the same issue after the update. Can someone have a look soonest?
- mlamie
I don't know what you mean with a view-only account. So far I know the issue is in the Android app, not the Domoticz installation it selfs. If you have some instructions or suggestions I can try to provide you details to troubleshoot.galadril wrote:Can you create a view-only account for me and pm me the details?mlamie wrote:In the Play store the 4 latest comments did report the same issue after the update. Can someone have a look soonest?
P.s. I already cleared the caches and removed the app and reinstalled it. Did not help.
