galadril
Domoticz version: latest
Re: Domoticz app 2.0
Post by galadril »
NiklasO wrote:Can't control blinds from the widget?
Would like to see "Open" and/or "Close" button..
Ill look into it
Shaggie_NB
Post by Shaggie_NB »
galadril wrote:
Shaggie_NB wrote:I'm still having problems with the graphs from the Gas and CO2 meters (they won't show). For Electricity and Temp they are working OK!
In the Domotictz (website) they are all working fine...
This was already mentioned by me but everybody was so busy with all the new (and great!) functionalities I thougt it would be picked up later.....
So here is my question again... ;)
Can you create a read-only account for me and PM me de details?
Did PM you but the message stays in my outbox??
galadril
Post by galadril »
Shaggie_NB wrote: Did PM you but the message stays in my outbox??
Should be fixed in next beta.
pollefinario
Post by pollefinario »
I've got a Philips 23" android touch screen. At the moment it is not able to install the app. Is this due to the screen resolution being in the config files?
The device is stuck at 4.2.2.
Any possibility to make this device compatible?
Thanks a lot.
Device info:
http://www.philips.nl/c-p/S231C4AFD_00/ ... cificaties
galadril
Post by galadril »
You can now also modify the user variables values in the next beta
martk
Post by martk »
Finally! Tried this a few times already but couldn't. Thanks :D
roblom
Post by roblom »
"Zet"?
Verstuurd vanaf mijn HTC One M9 met Tapatalk
galadril
Post by galadril »
Big feature in the next beta :)
Protect the app with your fingerprint :ugeek:
piokuc
Post by piokuc »
Please correct aligment text on dashboard in grid view. Should all text center or alligment to left.
galadril
Post by galadril »
piokuc wrote:Please correct aligment text on dashboard in grid view. Should all text center or alligment to left.
They should be centered.. maybe you have something where with your naming..?
piokuc
Post by piokuc »
Yes. Some naming is center and is ok but some is not center.. look on my screen.
Example:
TV salon -KWh is ok
But temperatura -"wschód" is not ok.
piokuc
Post by piokuc »
Today i install new beta and alligment is still problem.
Next problem is that option Configuration server download not working. When i click on this it nothing do.
MarcelMAH
Domoticz version: v3.8025
Post by MarcelMAH »
I recieved the non beta update yesterday and AGAIN I had to remove my data from the app to be able to use it again (after setting it up again) :cry:
Running Domoticz on Ubuntu 16.04 on VMware with RFXCOM - RFXtrx433 and Aeotec Z-Stick Gen5
jannl
Domoticz version: 2026.1.x
Post by jannl »
In the new update all settings where gone. Remaining problem is that it is not possible to set the protocol to https (every time I look it is back to http). I do not use the standard https port.
mlamie
Domoticz version: 3.5877
Post by mlamie »
The latest update caused an issue which I can not resolve. With version (0.1.316) something changed in the network configuration. Normally I only connect via the local ip (192.168.x.x) and if I'm outside I use openvpn. Can someone help me! P.s. via an internet browser everything works fine.
Raspberry Pi 3, RaZberry, RFXtrx433
Various Z-Wave devices, KlikAanKlikUit devices, ESP8266 NodeMCU, Sonoff POW and a Essent E-thermostaat
IP camera: Dahua 4MP IPC-HDBW4421R-AS, Vivotek FD8134V
Shaggie_NB
Thanks!!!!
In te new beta all graphs are working OK.
Keep up the great work!!
Timdgr
Post by Timdgr »
galadril wrote:From the play store device compatibility list:
So according to that list, it should work if plain Nexus 7 means the original 2012 version...
Unfortunately i can't install it. Too bad that it does not give any clue on why it refuses to install.
I googled around a bit and found some instructions on clearing google play cache and such but didn't help out. :(
Any ideas?
I'm actually running the Domoticz lite version 0.1.243 app on the very same tablet...
even more strange isn't it? Or have requirements changed since that version?
mlamie
Post by mlamie »
mlamie wrote:The latest update caused an issue which I can not resolve. With version (0.1.316) something changed in the network configuration. Normally I only connect via the local ip (192.168.x.x) and if I'm outside I use openvpn. Can someone help me! P.s. via an internet browser everything works fine.
In the Play store the 4 latest comments did report the same issue after the update. Can someone have a look soonest?
galadril
Post by galadril »
mlamie wrote:In the Play store the 4 latest comments did report the same issue after the update. Can someone have a look soonest?
Can you create a view-only account for me and pm me the details?
mlamie
Post by mlamie »
I don't know what you mean with a view-only account. So far I know the issue is in the Android app, not the Domoticz installation it selfs. If you have some instructions or suggestions I can try to provide you details to troubleshoot.
P.s. I already cleared the caches and removed the app and reinstalled it. Did not help.
