http://127.0.0.1:1989/json.htm?type=command¶m=system_rebootCould you help me?
Thank you
http://127.0.0.1:1989/json.htm?type=command¶m=system_rebootCode: Select all
http://127.0.0.1:8080/json.htm?type=command¶m=system_rebootCode: Select all
sudo shutdown -r nowSweetPants wrote:On Linux (Ubuntu 14.04 LTS)works fine from a virtual switch on my system.Code: Select all
Doeswork from the CLI?Code: Select all
