Reboot Switch for RaspberryPi
Mazzokun
Post by Mazzokun »
Hello, I created a virtual switch to restart the raspberry pi and I place this json url in the on action field:
http://127.0.0.1:1989/json.htm?type=command&param=system_reboot
but the pi doesn't restart..
Could you help me?
Thank you
GoranLundberg
Re: Reboot Switch for RaspberryPi
Post by GoranLundberg »
I would guess that the user running domoticz doesn't have permission to reboot the machine.
Which user are you running domoticz as? pi?
For domoticz to be able to reboot the machine it needs to run as root or as sudo root.
But it's not recommended to run domoticz as a root user due to security reasons.
Server: Raspberry Pi1 B+ Hardware: RFXCOM - RFXtrx433 USB Transciever Domoticz: Beta Channel Keybase: https://keybase.io/goranlundberg
SweetPants
Post by SweetPants »
On Linux (Ubuntu 14.04 LTS)
http://127.0.0.1:8080/json.htm?type=command&param=system_reboot
works fine from a virtual switch on my system.
Does
sudo shutdown -r now
work from the CLI?
jannl
Domoticz version: 2022.2
Post by jannl »
Works for me. Do you have any messages in the logfile?
Mazzokun
Post by Mazzokun »
SweetPants wrote:On Linux (Ubuntu 14.04 LTS)
Does
work from the CLI?
now works :D
Thank you:)
