Recently I've bought a raspberry pi with the aeon gen5 stick and a RFXtrx433.
Main reason is to play around with the capabilities before we move into a new house.
I added the promax kaku switches from the action by using the workaround I found on this forum and
it works like a charm.
Then I added a FGSD-002 which was detected automatically.
Then I added a FGMS-001 which was detected as an unknown device. I found a workaround here by copying
another line in the manufacturer_specific.xml and adjusting the product type value.
However now I find myself with a bunch of 'unknown' named devices in the device list and I'm wondering how this
should be populated. I do find all the device names in a few posts, but should this have been filled in by domoticz
automatically? or is there a place with a list of ID's available ?
The motion sensor; http://i.imgur.com/yrPsEUJ.png
The smoke sensor; http://i.imgur.com/Vv7QdmR.png
edit: Changed the images to links.
Which unknown device is what?
dvvelzen
- Domoticz version: 3.4834
Raspberry Pi v3 + RFXCom + Aeon Labs Gen5 + Domoticz
3x Promax CoCo plugs
1x FGSD-002 | 1x FGMS-001
MartenW
Re: Which unknown device is what?
I have the same problem. In my device list are a lot of devices with various ID and Unit.
No idea where these Id and unit comes from.
Makes it difficult to find a new device because a device can have more id's and unit's in the device list.
So who can inform me:
how to obtain the real ID / unit code is of a kaku device is
how to prevent rfxcom to detect the same devices with another id.
how to change devices with the same ID and a different unit number
Domoticz V3.4834
RFXCOM - RFXtrx433 USB 433.92MHz Transceiver
Version: 243
Kaku devices
Domoticz V3.4834
Version: 243
Kaku devices
piotr
With Kaku you will allways see unknown devices because your RFXcom will pickup devices from neighbours etc. Uncheck "Accept new Hardware Devices" in Settings and "Allow for 5 minutes" when adding devices.
- gizmocuz
+1piotr wrote:With Kaku you will allways see unknown devices because your RFXcom will pickup devices from neighbours etc. Uncheck "Accept new Hardware Devices" in Settings and "Allow for 5 minutes" when adding devices.
Users browsing this forum: HansSch and 1 guest
