Themes not loading
mvzut
Themes not loading
Post by mvzut »
Since a month or so (always on latest beta) I keep seeing the same theme no matter which I select. I tried emptying caches etc. but to no avail. I have this problem with all browsers that I us: (mobile) Safari, Chrome and Edge. Any tips?
gizmocuz
Re: Themes not loading
Post by gizmocuz »
Open your browsers developer console and goto the network tab
then change the theme, does it report any issues here?
mvzut
Post by mvzut »
I'm not so familiar with the developer console, so don't know what to look for in the network tab. No obvious error messages though.
I did succeed in loading the new theme by clearing the cache another few times and hitting the reload button. Seems I have to do that every time I load a new theme!? In the past I can't remember that this was neccessary. Is there anything that can be done about this?
gizmocuz
Post by gizmocuz »
Do you also have this problem with the stock themes, like the simple-gray theme ?
leecollings
Post by leecollings »
For what it's worth, I have the same issue, it's almost as though the cache doesn't refresh, and the same theme is stuck 'ON'.
bdormael
Post by bdormael »
Same Issue here
Sergio
Domoticz version: 3.9639
Post by Sergio »
Chrome showing:
Use of the Application Cache is deprecated on insecure origins. Support will be removed in the future. You should consider switching your application to a secure origin, such as HTTPS. See https://goo.gl/rStTGz for more details.
/#/Dashboard:1 Document was loaded from Application Cache with manifest http://192.168.11.245/html5.appcache
/#/Dashboard:1 Application Cache Checking event
/#/Dashboard:1 Application Cache NoUpdate event
jquery-1.12.0.min.js:4 Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check https://xhr.spec.whatwg.org/.
Entering the page through https showed for a sec. a red message telling somethig like "...cache manifest loading failed..."
I don't know if it's related.
EDIT: Gocha! "Browser cache refresh failed. Manifest fetch failed (9). https://192.168.1.10/html5.appcache"
9 might indicate a certificate error. For local accessing it would be better to not use a certificate.
OCB73
Domoticz version: 3.4834
Post by OCB73 »
I had the same problem (cache manifest) using firefox. When i cleared cache and offline-data in firefox, themes were loading.
Since i wired my raspi instead of using wlan, problem is gone. Maybe it helps someone.
Oliver
Sergio
Post by Sergio »
The connection method shouldn't make a difference while you have a good network configuration, both should be the same.
I had so many problems with web page catching on my application in the past, it's not an easy or nice thing to work on.
Enviado desde mi A0001 mediante Tapatalk
