Themes not loading
Themes not loading
Since a month or so (always on latest beta) I keep seeing the same theme no matter which I select. I tried emptying caches etc. but to no avail. I have this problem with all browsers that I us: (mobile) Safari, Chrome and Edge. Any tips?
- gizmocuz
Re: Themes not loading
Open your browsers developer console and goto the network tab
then change the theme, does it report any issues here?
I'm not so familiar with the developer console, so don't know what to look for in the network tab. No obvious error messages though.
I did succeed in loading the new theme by clearing the cache another few times and hitting the reload button. Seems I have to do that every time I load a new theme!? In the past I can't remember that this was neccessary. Is there anything that can be done about this?
- gizmocuz
Do you also have this problem with the stock themes, like the simple-gray theme ?
- leecollings
For what it's worth, I have the same issue, it's almost as though the cache doesn't refresh, and the same theme is stuck 'ON'.
Same Issue here
- Domoticz version: 3.9639
Chrome showing:
Entering the page through https showed for a sec. a red message telling somethig like "...cache manifest loading failed..."
I don't know if it's related.
EDIT: Gocha! "Browser cache refresh failed. Manifest fetch failed (9). https://192.168.1.10/html5.appcache"
9 might indicate a certificate error. For local accessing it would be better to not use a certificate.
Use of the Application Cache is deprecated on insecure origins. Support will be removed in the future. You should consider switching your application to a secure origin, such as HTTPS. See https://goo.gl/rStTGz for more details.
/#/Dashboard:1 Document was loaded from Application Cache with manifest http://192.168.11.245/html5.appcache
/#/Dashboard:1 Application Cache Checking event
/#/Dashboard:1 Application Cache NoUpdate event
jquery-1.12.0.min.js:4 Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check https://xhr.spec.whatwg.org/.
- Domoticz version: 3.4834
I had the same problem (cache manifest) using firefox. When i cleared cache and offline-data in firefox, themes were loading.
Since i wired my raspi instead of using wlan, problem is gone. Maybe it helps someone.
Oliver
Oliver
The connection method shouldn't make a difference while you have a good network configuration, both should be the same.
I had so many problems with web page catching on my application in the past, it's not an easy or nice thing to work on.
Enviado desde mi A0001 mediante Tapatalk
