Real-time solar data : azimuth, Altitude, Lux sensor... [closed]
vmb
Re: Real-time solar data : azimuth, Altitude, Lux sensor...
@derik: whats your question?
Can also send me a pm in Dutch. Perhaps I can help you, although the wiki is very clear. Only problem I encountered was to put JSON.lua in scriptfolder on my Pi3. After that all went right.
Derik
- Domoticz version: BETA
I did all the things in the wiki.
Only my script is not working.
I did not get the:
And my log error:
I did not get the:
Your home altitude : run once in debug = 1 to found your altitude in Log and write it here
2016-08-20 12:55:00.557 Error: EventSystem: in /home/linaro/domoticz/scripts/lua/script_time_SolarSensor.lua: .../linaro/domoticz/scripts/lua/script_time_SolarSensor.lua:56: attempt to call a nil valueXu4: Beta Extreme antenna RFXcomE,WU Fi Ping ip P1 Gen5 PVOutput Harmony HUE SolarmanPv OTG Winddelen Alive ESP Buienradar MySensors WOL Winddelen counting RPi: Beta SMAspot RFlinkTest Domoticz ...Different backups
vmb
@Derik:
I noticed three different things in your setup:
- The names of the custom sensors should be :"Sun Azimuth" and "Sun Altitude" Exactly like in the wiki.
- In the box of these custom sensors (click on "aanpassen") Type at the field "Aslabel" the word 'degrees' at both custom sensors.
- The name of the Weather Underground location voor Nijmegen should be "Nijmegen" or try "Molukkenstraat" You used the Weather Underground codename of the station in your script. During installation I got the same failure message. Once I changed the name in the script, all went right.
(Molukkenstraat (INIJMEGE14)
Give it a try!
Give it a try!
- capman
Got the folowing error in my log
2016-08-20 16:35:00.788 Error: EventSystem: in /usr/local/domoticz/var/scripts/lua/script_time_SolarSensor.lua: /usr/local/domoticz/var/scripts/lua/json.lua:352: bad argument #1 to 'len' (string expected, got table)
A used the last beta version (v3.5523). And it runs on a synology , so a changed the line for json.lua in the script to the correct path.
Any idea ?
Any idea ?
Derik
@ VMB [ From Nijmegen??
I did what you say..
Only the wiki has some errors i think
The Wiki: And what you says:[ and i have ] Only i think i don not now how i run in debug for 1 time:
While i got this setting:
Changed my api.
local altitude = 27 -- Your home altitude : run once in debug = 1 to found your altitude in Log and write it here
local WMOID = '07145' -- Your nearest SYNOP Station for ogimet (to get Cloud layer). Run once with debug=1 to get it in the log. (or, better, choose it there : http://www.ogimet.com/gsynop_nav.phtml.en )
local DEBUG = 0 -- 0 , 1 for domoticz log , 2 for file logXu4: Beta Extreme antenna RFXcomE,WU Fi Ping ip P1 Gen5 PVOutput Harmony HUE SolarmanPv OTG Winddelen Alive ESP Buienradar MySensors WOL Winddelen counting RPi: Beta SMAspot RFlinkTest Domoticz ...Different backups
Derik
And:
with this?
And i have:
Changed something.
Only the error:
Is there
Only the error:
2016-08-20 21:15:00.225 Error: EventSystem: in /home/linaro/domoticz/scripts/lua/script_time_SolarSensor.lua: .../linaro/domoticz/scripts/lua/script_time_SolarSensor.lua:56: attempt to call a nil valueXu4: Beta Extreme antenna RFXcomE,WU Fi Ping ip P1 Gen5 PVOutput Harmony HUE SolarmanPv OTG Winddelen Alive ESP Buienradar MySensors WOL Winddelen counting RPi: Beta SMAspot RFlinkTest Domoticz ...Different backups
vmb
@Derik
No, not from Nijmegen. From Alblasserwaard.
Guess you checked the Idx-numbers from all the sensors?
Only thing I can think of is changing "Molukkenstraat" in "Nijmegen". Perhaps you tried that already? Check Weather Underground for stations/names nearby.
Debug can be found in Domoticz-log when you set is to value '1'.
You did put JSON.lua in script directory?
Hope this helps, because my knowledge of this script is coming to an end.
Succes!
Succes!
Derik
@vmb
Not working
Please some screendumps of your settings...
script, sensors etc,,
Not working
vmb
@Derik,
Here is my script; only changed the WU-api
-- Variables to customize ------------------------------------------------
local city = "Liesveld" -- Your city for Wunderground API
local countryCode = "NL" -- Your country code for Wunderground API
local idxLux ='428' -- Your virtual Lux Device ID
local idxSolarAzimuth ='429' -- Your virtual Azimuth Device ID
local idxSolarAltitude ='430' -- Your virtual Solar Altitude Device ID
local idxUserVarOcta='7' -- Your user variable ID , named octa
local wuAPIkey = "6e4404XXX" -- Your Weather Underground API Key
local latitude = 51.885823 -- your home
local longitude = 4.662413 -- your home
local altitude = -2 -- Your home altitude : run once in debug = 1 to found your altitude in Log and write it here
local WMOID = '06344' -- Your nearest SYNOP Station for ogimet (to get Cloud layer). Run once with debug=1 to get it in the log. (or, better, choose it there : http://www.ogimet.com/gsynop_nav.phtml.en )
local DEBUG = 1 -- 0 , 1 for domoticz log , 2 for file log
-- and customize the URL of api.wunderground around line 104 according to your country.
-- Below , edit at your own risk ------------------------------------------
vmb
And here is my JSON.lua in a rar file. Unrar it and place it in script-dir (same dir as where Solar script is placed)
- JSON.rar
- (9.48 KiB) Downloaded 150 times
Derik
mmm
How do you come to otca value 8?
And do i need to rename the JSON.lua to script_time_JSON.lua?
- capman
Okee, it's working now. Replace my original json.lua file with yours.
Thanks vmb
Thanks vmb
vmb
My octa is 7 because I use other variables. Thats why this is number 7.Derik wrote:mmm
Json extract from rarfile. Leave name as it is.
vmb
Great nice to hear this helped you out.capman wrote:Okee, it's working now. Replace my original json.lua file with yours.
Thanks vmb
Derik
mmm
You guys run on Windows???
I see:
Change this to my cubieboard.
And this: Changed here my things
And here:
I removed the -- and set my Cubieboard IP:port
And here: Removed the -- and set my IP:Port
Only:
my dummy's are red..
I see:
json = (loadfile "/home/linaro/domoticz/scripts/lua/JSON.lua")() -- For Linux
-- json = (loadfile "D:\\Domoticz\\scripts\\lua\\json.lua")() -- For WindowsAnd this:
local config=assert(io.popen('curl http://api.wunderground.com/api/'..f4cf6d9992844b..'/conditions/q/'..NL..'/'..Nijmegen..'.json')) -- customize here !!
And here:
--os.execute('curl "http://192.168.5.70:8080/json.htm?type=command¶m=updateuservariable&idx='..idxUserVarOcta..'&vname=octa&vtype=0&vvalue='..tostring(Octa)..'"')
And here:
cmd='curl "http://192.168.5.70:8080/json.htm?type=command¶m=udevice&idx='..idxLux..'&svalue='..tostring(round(weightedLux,0))..'"'
Only:
Derik
-- and customize the URL of api.wunderground around line 104 according to your country.Xu4: Beta Extreme antenna RFXcomE,WU Fi Ping ip P1 Gen5 PVOutput Harmony HUE SolarmanPv OTG Winddelen Alive ESP Buienradar MySensors WOL Winddelen counting RPi: Beta SMAspot RFlinkTest Domoticz ...Different backups
vmb
Derik, I'm running on a Pi3.
I only changed the custumizable lines in the script. Nothing else, not even around line 104.
Derik
please your total script without the api...
going creazy here..
Other error:
going creazy here..
Other error:
2016-08-21 14:30:05.265 Error: EventSystem: in /home/linaro/domoticz/scripts/lua/script_time_SolarSensor.lua: .../linaro/domoticz/scripts/lua/script_time_SolarSensor.lua:97: attempt to perform arithmetic on global 'relativePressure' (a nil value)
2016-08-21 14:30:01.877 (D.M.: RFXcomE) Wind (D.M.: Wind)Xu4: Beta Extreme antenna RFXcomE,WU Fi Ping ip P1 Gen5 PVOutput Harmony HUE SolarmanPv OTG Winddelen Alive ESP Buienradar MySensors WOL Winddelen counting RPi: Beta SMAspot RFlinkTest Domoticz ...Different backups
Derik
i am not stupid...
Think there is something more wrong then my stupid actions..
Wiki step by step..
And no luck...
Please update the wiki so thing are correct....
Wiki step by step..
And no luck...
trixwood
From the original wiki
without weathe underground you need to repalce that with:
or read it from a pressure sensor...
That yould fix your nil... now I am also stuck on the cloud coverage not coming in....
-- API Wunderground
local config=assert(io.popen('curl http://api.wunderground.com/api/'..wuAPIkey..'/conditions/q/'..countryCode..'/'..city..'.json'))
local location = config:read('*all')
config:close()
local jsonLocation = json:decode(location)
if( DEBUG == 1) then
local latitude = jsonLocation.current_observation.display_location.latitude
local longitude = jsonLocation.current_observation.display_location.longitude
local altitude = jsonLocation.current_observation.display_location.elevation
print('Lat: '..latitude..'Long: '..longitude..'Alt: '..altitude)
relativePressure = jsonLocation.current_observation.pressure_mb -- if you have an another way to get the Pressure, (local barometer ...) then you may optimize the script and avoid the call to api.wunderground)
relativePressure = 1012
