Cheap chinese z-wave products
trixwood
Re: Cheap chinese z-wave products
PD01ZE not PD01TE I hope, pfff...
I hope I get my money back...
how to you make a case by ali without getting into an argument with the shop?
Derik
- Domoticz version: BETA
And say you ask a Eu version or something else...trixwood wrote:PD01ZE not PD01TE I hope, pfff...
Say refund only because the shippingcost are more then the item cost..
Wait a few days.
Perhaps sometimes not al the money... most of time
Derik
mmm..
Did the old Rob trick..
First exclude and then include....
And yes..
4 switches and a LUX sensor....!
And battery life... Only i do not understand a %^$^*%$*%^of that OZW xml story...[ my englisch is to bad ]
Perhaps some one will help me to make this
So i can send it to OZW.
And yes..
trixwood
Yeah, I send a present to a friend of my in hong kong, 25 euro to track and trace to china for a light package as big as a cola can, I was like
Derik
And no settings...
Perhaps tomorrow... [ must wait more the 12 hours.. for zwave] Or is this after add to OZW vissable?
- LouiS22
Have you read my post?Derik wrote:And no settings...
Derik
This part:LouiS22 wrote:Have you read my post?Derik wrote:And no settings...
Yes..Here's the extract of the manual: http://www.pepper1.net/zwavedb/device/894, one can make the xml for OZW.
Only that is the part i do not understand...
trixwood
Two have to create/combine/set them on fire/alter/edit existing xml files...
somebody should write a howto: how to edit openzwave xml files... or maybe there is already something out there describing it...
https://github.com/OpenZWave/open-zwave ... ng-Devices
good luck!
good luck!
- LouiS22
Derik, I've commited the xml into OZW. It's not yet merged into the master, but hopefully it won't take long. Note, this doesn't mean you can fully use, because first gizmocouz have to update the OZW built into Domoticz. Of course you can put the relevant files into their correct location, but this is a temp solution and you have to repeat it every time you upgrade Domoticz.Derik wrote:This part:LouiS22 wrote:Have you read my post?Derik wrote:And no settings...
ScreenShot190.jpgYes..Here's the extract of the manual: http://www.pepper1.net/zwavedb/device/894, one can make the xml for OZW.
Derik
LouiS22 wrote:Derik, I've commited the xml into OZW. It's not yet merged into the master, but hopefully it won't take long. Note, this doesn't mean you can fully use, because first gizmocouz have to update the OZW built into Domoticz. Of course you can put the relevant files into their correct location, but this is a temp solution and you have to repeat it every time you upgrade Domoticz.Derik wrote:This part:LouiS22 wrote:
Have you read my post?Yes..Here's the extract of the manual: http://www.pepper1.net/zwavedb/device/894, one can make the xml for OZW.
I"am a "Bouwvakker", and no ICT expert
cogliostrio
I updated OZW today, and these popped up. Any feedback on how they work?
- shenzen_neo_xml.png (2.35 KiB) Viewed 3170 times
Skippiemanz
- Domoticz version: 4.10233
Normally exclude and include should do it. But i dont know where these files are. Perhaps you need to copy them into your zwave domoticz config folder
Derik
when these files are not in to Domoticz core..
After an update the files are gone...
Derik
trixwood wrote:Could you not just order from alibaba? They accept paypal and have 1 piece items.
https://szneo.en.alibaba.com/productgro ... ensor.html
https://szneo.en.alibaba.com/product/60 ... _Wifi.html
https://szneo.en.alibaba.com/product/60 ... ntrol.html
Whe can buy 10 pieces... whit all ....
- LouiS22
The Power Plug is working as it shouldcogliostrio wrote:I updated OZW today, and these popped up. Any feedback on how they work?
- LouiS22
Yes, that's normal - but I wrote you that before. But you can always copy back them if you want to use these devices. Eventually they'll be in domoticz, we just have to wait.Derik wrote:when these files are not in to Domoticz core..
Derik
I now ...LouiS22 wrote:Yes, that's normal - but I wrote you that before. But you can always copy back them if you want to use these devices. Eventually they'll be in domoticz, we just have to wait.Derik wrote:when these files are not in to Domoticz core..
I mean this to.
cogliostrio And the EYE is working great to.
Incl the LUX!!!.. [ sleep when no differences... battery save ]
- LouiS22
Shenzen NEO's stuff are in the latest beta.
Derik
Great....!!!LouiS22 wrote:Shenzen NEO's stuff are in the latest beta.
Only Domoticz does not reconice the sensor?
And unfortunately..
Only now the are expensive..
Almost like all other Zwave devices
- LouiS22
You have te exclude first, then include it again... Also, the latest BETA is .560, yours is still .541...Derik wrote:Great....!!!LouiS22 wrote:Shenzen NEO's stuff are in the latest beta.
And unfortunately..
