[MyDomoAtHome] Support thread
Evelen
Domoticz version: 2.4538
Re: [MyDomoAtHome] Support thread
Post by Evelen »
ImperiHome updated, animated custom icons (on and off state) is now possible :D
naitsirhc
Post by naitsirhc »
Which version 2.8.1???
Kind regards
Und Tschjuß
naitsirhc
Post by naitsirhc »
New version MDAH released....
Thanks epierre
Und Tschjuß
Lukewalker
Post by Lukewalker »
Dear all,
I installed domoticz, mydomoathome and I configured the system on imperihome, without any issue or problem I checked the device list by http address and this is the result
{"devices":[{"id":"S0","name":"MyDomoAtHome","type":"DevGenericSensor","params":[{"key":"Value","value":"0.1.51","unit":"","graphable":"false"}]},{"id":"SC1","name":"Test","type":"DevScene","room":"Scenes","params":[{"key":"LastRun","value":1465577487000}]},{"id":"3","name":"Flood","type":"DevSwitch","params":[{"key":"Status","value":"0"}]},{"id":"4","name":"Switch","type":"DevSwitch","params":[{"key":"Status","value":"0"},{"key":"Energy","value":"0.0"}]},{"id":"C0","name":"Sala","type":"DevCamera","room":"Switches","params":[{"key":"localjpegurl","value":"video/mjpg.cgi"}]},{"id":"C1","name":"Camera","type":"DevCamera","room":"Switches","params":[{"key":"localjpegurl","value":"/image/jpeg.cgi"}]}]}
But when I try to search the devices on iOS Ididn't find any device, instead if I try on android I see only a sensor called mydomeathome.
Do you have any suggestion?
Luca
DRuw
Post by DRuw »
Hi guys, I have an issue with the graphs and data of the energy meters.
Ive got all things running (see previous posts in this topic) and since last week I have installed solar panels.
Domoticz show a negative number when I produce more energy than I consume and also in the webinterface I have 4 graphs: use high rate, use low rate and proction high an low.
In domoticz this work perfect and looks great but in the mobile interface of imperihome it all goes south...
It seems that only consumption is used and the production isnt?
Can this be changed???? (should be, Domotics is correct...)
I just updated everything as far as I know (still noob here) but nothing has changed..
Thanks in advance!!!
DRuw
Post by DRuw »
nothing?
ripp2003
Domoticz version: latest B
Post by ripp2003 »
Here, a description of what I have :
-> RPI 2 +
-> Raspbian Jessie
-> Domoticz beta 3.5273
-> MyDomoAtHome (latest version in nodejs)
-> imperihome 2.7 (but latest playstore version tested to)on 2 phones and 3 tablet
Imperihome is very long to make action or retrieve data from my domoticz server.
exemple, I click on "Switch on light", imperihome say "On" but the action takes 7 even more seconds !
With the non-node js version, it was 3 seconds.
Yesterday, I have tested the oldest ISS-Domo : great, justs 3 seconds and retrieve is very quick but lot of bugs...
MydomoatHome recognize more and better my materials in domoticz.
Could you tell me why it take so long ?
I can see when I make a top than the command node (www-data) can take up to 75% of cpu.
Also, accessing to http://myip:5001:devices take 10 seconds.
Really don't know what happened
devices.txt
(8.89 KiB) Downloaded 86 times
mvzut
Post by mvzut »
I also have issues with the new MyDomoAtHome. I completely re-installed my Raspberry Pi 2B with a fresh install of Domoticz etc. a couple of days ago. It was at that moment that I found out that the installation of MyDomoAtHome had completely changed. At first I was pleased with the changes: smoother installation, better recognition of devices and rooms/categories in Imperihome. But then I found out that this the new Javascript implementation has two MAJOR drawbacks on my system:
  • My Raspberry Pi uses around 10% cpu when Imperihome is running. This used to be around 3%.
  • Loading graphs takes ages! From a few seconds with the "old" version to >10 seconds now
Are these aspects that are still being worked on? Or do I just have to live with them, or switch over to a faster system?
P.S. I don't have the problems that ripp2003 describes, operating switches etc. is almost instantaneous
rhb3rg
Post by rhb3rg »
Lukewalker wrote:Dear all,
Luca
Exactly same same problem here with fresh install of MDAH.
Everything seems to work in the URL but won't work in the ImperiHome (lite) app, with same thing, I can see only one sensor called MyDomoAtHome.
Any clue?
Evelen
Post by Evelen »
does anyone know of a way to hide the imperihome-line on top?
Also, any way to change og remove the logo for temp and humidity?
Thomasdc
Post by Thomasdc »
Hi!
Its probably allready answered but i dint find it back in the forum or wiki (maybe handy to add it in the wiki)
my setup:
Domoticz and imperhome are working fine (without users/passwords)
now i wanted to add users and passwords in my domoticz system but now i cant get the app imperihome working anymore..
do i need to do something more then just fill in the 'admin' and 'passsword' field in the configuration wizard in the app?
(so without any sort of authentification (blank password and user) was it all working fine, now i added some users and i cant get imperihome working anymore.. )
Bastien
Post by Bastien »
I would like to install MyDomoAtHome but Domoticz is running on Windows environment...Does someone have a corresponding installation guide for me...?
Thank you very much !!
Polygontrauma
Post by Polygontrauma »
Thanks to some hints in this thread I finally got it working!
But it seems that the "mydomoathome" service does not start automatically when I reboot my RPi, so I have to start it manually each time. Is there a way to start it automatically after a reboot?
superczar
Post by superczar »
Recently switched to an iOS device and installed this on a spare RPI2 (separate from the primary domoticz system)
Works great except one odd glitch, while all devices show up on the MDAH gateway , around 36 of my 44 switches show up but 8 are missing on the imperihome app
The missing ones are again quite random - As in it isn't that switches of any particular type are missing e.g. 5 out of 7 lights reported as DevRGB on the MDAH show up on the app but 2 are missing
antares
Post by antares »
Sorry if I did a mistake, but I added a MyDomoAtHome question as thread here (to make search easier): viewtopic.php?f=21&t=13560
If that's wrong, I can move the question over here.
gilzin
Post by gilzin »
hi there
i have Temperature Sensors on my DOM but i cant see them on the IMPERIHOME app, how can i add them?
tnx
antares
Post by antares »
Hi glizin,
can you please post the output of http://<yourdomo>:3002/devices and the MyDomoAtHome log?
gilzin
Post by gilzin »
here it is:
{"devices":[{"id":"S0","name":"MyDomoAtHome","type":"DevGenericSensor","params":[{"key":"Value","value":"0.1.51","unit":"","graphable":"false"}]},{"id":"SC1","name":"הדלקה","type":"DevScene","room":"Scenes","params":[{"key":"LastRun","value":1474920281000}]},{"id":"SC2","name":"test2","type":"DevMultiSwitch","room":"Scenes","params":[{"key":"LastRun","value":1475220987000},{"key":"Value","value":"Off"},{"key":"Choices","value":"On,Off"}]},{"id":"4","name":"סלון ראשי","type":"DevSwitch","room":"Switches","params":[{"key":"Status","value":"0"}]},{"id":"6","name":"cam1","type":"DevSwitch","room":"Switches","params":[{"key":"Status","value":"1"}]},{"id":"8","name":"אי","type":"DevSwitch","room":"Switches","params":[{"key":"Status","value":"0"}]},{"id":"9","name":"גינה דשא","type":"DevSwitch","room":"Switches","params":[{"key":"Status","value":"0"}]},{"id":"10","name":"מרפסת","type":"DevSwitch","room":"Switches","params":[{"key":"Status","value":"0"}]},{"id":"7","name":"מטבח","type":"DevSwitch","room":"Switches","params":[{"key":"Status","value":"0"}]},{"id":"20","name":"מזגן","type":"DevSwitch","room":"Switches","params":[{"key":"Status","value":"0"}]},{"id":"13","name":"שביל כניסה","type":"DevSwitch","room":"Switches","params":[{"key":"Status","value":"0"}]},{"id":"14","name":"תריס מרפסת","type":"DevShutter","room":"Switches","params":[{"key":"Status","value":1},{"key":"Level","value":"100"},{"key":"stopable","value":"0"},{"key":"pulsable","value":"0"}]},{"id":"15","name":"תריס פינת אוכל","type":"DevShutter","room":"Switches","params":[{"key":"Status","value":1},{"key":"Level","value":"100"},{"key":"stopable","value":"0"},{"key":"pulsable","value":"0"}]},{"id":"16","name":"תריס מטבח","type":"DevShutter","room":"Switches","params":[{"key":"Status","value":1},{"key":"Level","value":"100"},{"key":"stopable","value":"0"},{"key":"pulsable","value":"0"}]},{"id":"17","name":"סלון משני","type":"DevSwitch","room":"Switches","params":[{"key":"Status","value":"0"}]},{"id":"18","name":"גרילר","type":"DevSwitch","room":"Switches","params":[{"key":"Status","value":"1"}]},{"id":"19","name":"פינת אוכל","type":"DevSwitch","room":"Switches","params":[{"key":"Status","value":"0"}]},{"id":"11","name":"Domoticz Security Panel","type":"DevGenericSensor","room":"Utility","params":[{"key":"Value","value":"Normal"}]},{"id":"22","name":"טמפרטורה","type":"DevTempHygro","room":"Temp","params":[{"key":"Hygro","value":63,"unit":"%","graphable":"true"},{"key":"Temp","value":27.2,"unit":"°C","graphable":"true"}]},{"id":"22_1","name":"טמפרטורה","type":"DevPressure","room":"Weather","params":[{"key":"Value","value":1011,"unit":"mbar","graphable":"true"}]},{"id":"23","name":"רוח","type":"DevWind","room":"Weather","params":[{"key":"Speed","value":"0.0","unit":"km/h","graphable":"true"},{"key":"Direction","value":"354","unit":"°","graphable":"true"}]},{"id":"C0","name":"cam","type":"DevCamera","room":"Switches","params":[{"key":"localjpegurl","value":"cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=*****&pwd=*****&"}]},{"id":"C1","name":"cam3","type":"DevCamera","room":"Switches","params":[{"key":"localjpegurl","value":"cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=*****&pwd=*******&"}]}]}
thanks
antares
Post by antares »
Can you post the output of your domoticz.log? You can start domoticz with -log /<directory>/domoticz.log to set the path.
gilzin
Post by gilzin »
when i try to activate my camera from imperihome i am getting "unable to read stream error"
the camera works fine from domoticz app
can some one knows why?
