SSL is not suported for synology ATM.Jango wrote:Hello is it difficult to install ssl for use with domoticz on a synology NAS?
You can use VPN or maybe MyDomoticz https://my.domoticz.com/mydomoticz/login
Jumbotroll
I am not familiar with zwave plus stick. Maybe your device is not supported?sanderl wrote:Thank, you. Do you have any direction where to search/look/start?
Thank you for your replies. I added pictures on the previous post (jou replied to). It's this stick (ZME_UZB1)jumbotroll wrote:I am not familiar with zwave plus stick. Maybe your device is not supported?sanderl wrote:Thank, you. Do you have any direction where to search/look/start?
Add your problem here: http://www.domoticz.com/forum/viewforum.php?f=24
Jumbotroll
Thank you for confirmation I also roll back to stable release and now battery status is proper updated. Also I found another bug in the latest beta. Data from the wind detector are not not show in the diagram. I can see only data from max last 7 days, once I back to stable version there is no issue with the wind data chart.jumbotroll wrote: UPDATE!
I have the same issue with 2.4020 after a reset of my browser.
Went back to stable release 2.3530 and it's ok again.
I think this is a bug in domoticz beta source.
Jumbotroll
My domoticz build for arch-ppc853x (DSM 4.2 or DSM 4.3) does NOT support OpenZwave, to much hazzel to compile.keurdelion wrote:After many efforts I won't comment here. I didn't succeed in configuring Domoticz on a Synology NAS 209+ under the latest version available DSM 4.2 AND an AEON Z-Stick GEN5.
AM I right if I say that this configuration will never work because Domoticz + Openzwave is definitely not compatible with older version than DSM 4.3? I just need a certitude from experts to stop searching uselessly.
Many thanks,
Keurdelion
Should work with reverse proxy within DSM 6.0.jumbotroll wrote:SSL is not suported for synology ATM.Jango wrote:Hello is it difficult to install ssl for use with domoticz on a synology NAS?
Jumbotroll
BTW SSL is supported in the latest builddobber wrote:Should work with reverse proxy within DSM 6.0.jumbotroll wrote:SSL is not suported for synology ATM.Jango wrote:Hello is it difficult to install ssl for use with domoticz on a synology NAS?
Jumbotroll
Great package! I'm switching from Pi to this build with my rfxtrx433e
I noticed this, but I get an error:jumbotroll wrote:BTW SSL is supported in the latest builddobber wrote:Should work with reverse proxy within DSM 6.0.jumbotroll wrote:
Jumbotroll
I am facing the same issue. All of the following addresses result in the 'invalid location' error:frankTV wrote:If I try to add your repo to my synology it returns " unknown location"
Does somebody understand why it does not work for me. Quite sure I use the proper URL.
http://jadahl.dscloud.me/sspks/
When using http://packages.synocommunity.com It works fine.
http://jadahl.dscloud.me/sspks/ is not in use!Andi80 wrote:I am facing the same issue. All of the following addresses result in the 'invalid location' error:frankTV wrote:If I try to add your repo to my synology it returns " unknown location"
http://www.jadahl.com/domoticz_stable_6/
http://www.jadahl.com/domoticz_beta_6/
http://packages.synocommunity.com is working fine!
I ticked the check box for third party distributors.
Any ideas?
Best,
Andi
What type NAS du you have?Andi80 wrote:Well, I used these two addresses and it gave me the aformentioned error. I also ticked the respective check box.
Gesendet von meinem ONE A2003 mit Tapatalk
DS716+II was not added on my server, but you can try again now.Andi80 wrote:DS716+II
I didn't try to install manually, yet.
Users browsing this forum: Varazir and 1 guest
