How to install Domoticz on a Synology NAS
jumbotroll
Re: How to install Domoticz on a Synology NAS
Post by jumbotroll »
Jango wrote:Hello is it difficult to install ssl for use with domoticz on a synology NAS?
SSL is not suported for synology ATM.
You can use VPN or maybe MyDomoticz https://my.domoticz.com/mydomoticz/login
Jumbotroll
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
jumbotroll
sanderl wrote:Thank, you. Do you have any direction where to search/look/start?
I am not familiar with zwave plus stick. Maybe your device is not supported?
Add your problem here: http://www.domoticz.com/forum/viewforum.php?f=24
Jumbotroll
Jumbotroll
sanderl
Post by sanderl »
Jumbotroll
Thank you for your replies. I added pictures on the previous post (jou replied to). It's this stick (ZME_UZB1)
http://www.z-wave.me/index.php?id=28
and
http://www.robbshop.nl/usb-stick-met-zwave-plus
and
http://tweakers.net/pricewatch/434681/z ... -plus.html
may help...?
It seems to be added to OpenZwave:
https://groups.google.com/forum/#!searc ... nVduC-7QUJ
dtech
Post by dtech »
jumbotroll wrote: UPDATE!
I have the same issue with 2.4020 after a reset of my browser.
Went back to stable release 2.3530 and it's ok again.
I think this is a bug in domoticz beta source.
Jumbotroll
Thank you for confirmation I also roll back to stable release and now battery status is proper updated. Also I found another bug in the latest beta. Data from the wind detector are not not show in the diagram. I can see only data from max last 7 days, once I back to stable version there is no issue with the wind data chart.
jumbotroll
NEW SERVER URL!
Domoticz Beta build:
http://www.jadahl.com/domoticz_beta/
Domoticz Stable build:
http://www.jadahl.com/domoticz_stable/
Jumbotroll
keurdelion
Post by keurdelion »
After many efforts I won't comment here. I didn't succeed in configuring Domoticz on a Synology NAS 209+ under the latest version available DSM 4.2 AND an AEON Z-Stick GEN5.
AM I right if I say that this configuration will never work because Domoticz + Openzwave is definitely not compatible with older version than DSM 4.3? I just need a certitude from experts to stop searching uselessly.
Many thanks,
Keurdelion
jumbotroll
keurdelion wrote:After many efforts I won't comment here. I didn't succeed in configuring Domoticz on a Synology NAS 209+ under the latest version available DSM 4.2 AND an AEON Z-Stick GEN5.
Many thanks,
Keurdelion
My domoticz build for arch-ppc853x (DSM 4.2 or DSM 4.3) does NOT support OpenZwave, to much hazzel to compile.
If anyone else has managed to compile , I do not know .
Jumbotroll
jumbo70
Post by jumbo70 »
Need some help with next step in installing domoticz.
I'm newby with Linux
Aim is to install jadahl package
domoticz_88f6282-5.2_2.0.3530-7.spk
which I believe should match my DS112+ with DSM5.2.
Before I installed debian chroot,
I can further use ssh and putty to go to chroot environment and do the required commandline entries.
What is now easy / preferred way to install?
I tried to edit the etc/apt/sources.list to add the jadahl repository but that leads to error (line not recognized). Is this method of adding Jadahl repositories possible/supported within chroot ? If yes what should be the correct entry in the sources.list file?
Next I tried manual install by downloading the spk file and copied the file (using winSCP) to a new directory domoticz within the chroot environment.
Subsequently tried manual install by
apt-get install domoticz_88f6282-5.2_2.0.3530-7.spk
but then the package is not found. Should I put the package in a specific directory ?
Should I in another way make clear that the package is available to install?
Please some advise.
Thanks,
Jumbo70
gdusordet
Post by gdusordet »
hi,
I had to reset my Aeotec Z-Stick Gen5 contoller which is connected to my Synology server. Each time I am rebooting Synology, it keep changing the serial port from /dev/ttyacm0 to /dev/ttyacm1 or /dev/ttyacm1 to /dev/ttyacm0. Any idea how to prevent it from changing the serial port after a restart?
thanks
G
dobber
Domoticz version: Beta..
Post by dobber »
Jumbotroll
Should work with reverse proxy within DSM 6.0.
Great package! I'm switching from Pi to this build with my rfxtrx433e
jumbotroll
Jumbotroll
BTW SSL is supported in the latest build :-)
Jumbotroll
mvveelen
Post by mvveelen »
Darn..... just installed the latest and it gives me a dead node (Qubino dimmer). Tried rebooting the Synology, healing the node, healing the ZWave network....nothing....
What could be the problem here?
Edit:
Just updated with the same package again and...same problem. But, after waiting about 15 minutes, the light suddenly turned on and when I checked, the node was alive again. Weird, but true.
Edit 2:
Just got a message that the node was dead again :( Shoot !!
Edit 3:
At the same time I updated Domoticz, the Qubino died. It revived for a few minutes as you can see above, but after that it was broken. I got a new one and that one is working fine now. Hope this one will stay alive :)
RPi3b+/RFXCOM rfxtrx433E/Shelly/Xiaomi Gateway/Philips HUE Lights/Atag Zone One/2 SunnyBoy inverters/AirconWithMe/P1 smartmeter/Domoticz latest Beta
dobber
Post by dobber »
jumbotroll wrote:
Jumbotroll
I noticed this, but I get an error:
2016-05-19 19:21:02.928 Error: WebServer(SSL) startup failed on address 0.0.0.0 with port: 8443: use_certificate_chain_file: No such file or directory
The ssl part just wont start for me. Any suggestions?
Joshuapr
Post by Joshuapr »
Its not impossible but its also not recommended. The best way to install is with the OSDial CD itself.
Andi80
Post by Andi80 »
frankTV wrote:If I try to add your repo to my synology it returns " unknown location"
Does somebody understand why it does not work for me. Quite sure I use the proper URL.
http://jadahl.dscloud.me/sspks/
When using http://packages.synocommunity.com It works fine.
I am facing the same issue. All of the following addresses result in the 'invalid location' error:
http://www.jadahl.com/domoticz_stable_6/
http://www.jadahl.com/domoticz_beta_6/
http://packages.synocommunity.com is working fine!
I ticked the check box for third party distributors.
Any ideas?
Best,
Andi
jumbotroll
Any ideas?
Best,
Andi
http://jadahl.dscloud.me/sspks/ is not in use!
You have to use these url for DSM 6.0 :
And remember to tick the check box Any Publisher
Take a look on my webpage for more info http://www.jadahl.com
Jumbotroll
Andi80
Post by Andi80 »
Well, I used these two addresses and it gave me the aformentioned error. I also ticked the respective check box.
Gesendet von meinem ONE A2003 mit Tapatalk
jumbotroll
Andi80 wrote:Well, I used these two addresses and it gave me the aformentioned error. I also ticked the respective check box.
What type NAS du you have?
Have you tried to download and install manually?
Jumbotroll
Andi80
Post by Andi80 »
DS716+II
I didn't try to install manually, yet.
jumbotroll
Andi80 wrote:DS716+II
DS716+II was not added on my server, but you can try again now.
Jumbotroll
