Zwave network toooooo complicated ? Topic is solved
Derik
Re: Zwave network toooooo complicated ?
Post by Derik »
delete all groups and place them in only group 1
pascalspits
Post by pascalspits »
Derik wrote:delete all groups and place them in only group 1
that is exactly what I do, I clean it up each time ...
... but why does it keep coming back (without touching anything) every few weeks/months ?
RasPi2 - Aeotec Z-Stick S2 - Fibaro multisensors - Fibaro RGBW dimmers - ETH08 relais boards
Derik
Post by Derik »
Check this:
http://www.domoticz.com/forum/viewtopic ... cfg#p90807
mcmikev
Post by mcmikev »
I also experience this behavior. Last night I turned on the lights in the bathroom to discover that all the other lights were also turning on (bedrooms of my childeren, so they woke up :-( )
When going to the zwave setup I see that 4 nodes are just like that in group 1 attached to the "broadcast" 255.
I cannot remove them from that group neither.
Something weird and funny is going on.
This only occurs after a reboot by the way!
pascalspits
mcmikev wrote:Something weird and funny is going on.
You bet !
question is : how do we fix this ? Because this behaviour leads to an unreliable home automation system ...
Derik
Post by Derik »
do you have the last beta??
pascalspits
3.5241
Derik
Post by Derik »
try the last beta....
mcmikev
Post by mcmikev »
I have the latest running and have same issues with that version.
Derik
Post by Derik »
mcmikev wrote:I have the latest running and have same issues with that version.
Did you check all the thing is say?
Show some screendump
mcmikev
Post by mcmikev »
I cannot delete 255 from group 1.
Only option I had (with plug modules at least, not with modules behind wall switches) to remove from z-wave network en include again.
Then it was fine again.
All other options do not work or help out.
I tried it all.
Derik
Post by Derik »
let me see something..
trixwood
Post by trixwood »
Whoever created zwave did not design it with user friendly in mind. That's for sure. Hours I wasted on zwave :-| to get stuff to work. There is a backup for config but no restore :-. Stuff like that.
Derik
Post by Derik »
trixwood wrote:Whoever created zwave did not design it with user friendly in mind. That's for sure. Hours I wasted on zwave :-| to get stuff to work. There is a backup for config but no restore :-. Stuff like that.
I Agree.....
Onlyw u can simple repleace the Zwcfg in Domoticz..
That's easy
Only when it is working good :-)
Is there a better solution..??
trixwood
Post by trixwood »
Replacing or deleting that will not work, the data of groups and network are stored on the usb controller.
Derik
Post by Derik »
Read the topic i post before...
When you do 1 thing wrong start again..
Please let me see the settings en the Zwcgf....
And yes start clean, with a clean USB, so reset ..[ read the manual ]
And reset all device, or exclude first, when you try to add them.
It is working great in Domoticz... [ most of time ]
pascalspits
Today AGAIN one of my RGBW dimmers suddenly showed a lot of connections to other devices in the "groups a natwork" table ...
There was no Domoticz reboot, no software upgrade ... nothing changed to the system ... just like this ... out of the blue !
it's also remarkable that this ONLY happens to RGBW dimmers ... never to PIR sensors or other Zwave devices ...
... every few weeks these "ghost-connections" suddenly appear on one or more of my Zwave Fibaro RGBW dimmers
This is very annoying because it means that this Zwave network is NOT stable at all ...
pascalspits
only 3 days later ... Domoticz did an update and AGAIN, phantom-Zwave connections appear out of the blue ...
it's really starting to drive me crazy ...
I have also looked into this "zwcfg" thing on the RasPi, but I couldn't delete the file with Filezilla, it wouldn't allow it ... strange ...
I keep cleaning up these tzables to keep everything "stable" ... but I can't say it's very relyable this way ...
I'm starting to wonder if this Zwave thing actually makes sense ... ?
Derik
Post by Derik »
Read this part...
http://www.domoticz.com/forum/viewtopic ... cfg#p83308
Step by step!!!
When this correct.
Remove all the strange groups.
And place all the groups in 1
pascalspits
Derik wrote:Read this part...
Step by step!!!
Login with Winscp...
Check if the zwcfg.xxx.xml is from the user and not from root.[ config map ]
Otherwise remove this file.
And reboot the pi or your hardware.
Check the zwcfg... not ROOT!!
And then wait a few hours...
it said : Owner : Root
so I deleted it
after rebooting, again the file re-appears : zwcfg_0x0184d692.xml - owner : Root
it shouldn't be owner : root ?
But it is ! WTF !!
After a few minutes it had rebuilt the Zwave network and now it looks "clean" ... but for how long ???
fingers crossed !
