I am new here but i am enjoying the software up till now.
I do have something weird happen and was wondering if i made a config error or i just have buggy equipment.
I currently run Domoticz on a Raspberry Pi with a RFXCom. The system runs really well and everything works as expected except my temperature sensors.
I have two temperature sensors from Ventus (WS155). One is on the roof of my house, combined with wind direction and speed, and one is in my computer room. The one in my computer room has a display on it. When it says 50C on Domoticz it does show the proper temp on the display of the sensor.
Every once in a while the temperature just jumps from around 24C to 50+C. It is always between that range. I must say if my computer room were to reach 50C i think i will need to move or something. haha
Is this a configuration error or are my sensors both just buggy?
By the way both sensors display the same behavior.
I hope someone has some ideas.
Wierd temp sensor question Topic is solved
minionbob
- Temp readings. Now both at 50C
- Capture.JPG (30.76 KiB) Viewed 1140 times
- Temp readings. One 50 plus the other 24 plus.
- temp1.JPG (34.11 KiB) Viewed 1151 times
mrf68
Re: Wierd temp sensor question
I have a similar problem with one of my temperature sensors. When it get below 0 degrees Celcius, in Domoticz it shows -25.6 degrees. So I use the 'sensorwu' script from the wiki and added a check, so when it reads -25.6 or lower it adds +25.6 to the value.
if
devicechanged[sensorwu] and
tonumber(sWeatherTemp) < -25.6
then
sWeatherTemp = sWeatherTemp + 25.6
commandArray['UpdateDevice'] = 579 .. '|0|' .. tostring(sWeatherTemp)
elseif
then
minionbob
Thanks for your reply.
any chance you can post your complete LUA scipt?
i keep getting a error saying:
attempt to compare nil with number
i must admit i am new to lua but my gut feeling says i should be reading the current temp somewhere before i try to edit it.
any thought?
any thought?
mrf68
Sure I can post the complete script.
What it does, is get the values from the real sensor and passes the temperature to the virtual temp sensor. So you first need to create a virtual temp sensor, put the idx of this new sensor in the script. Remember to change the name of the real sensor in the script with the name of your own sensor. And save it in the LUA dir with the name script_device_something.lua.
More info in the wiki: https://www.domoticz.com/wiki/Virtual_weather_devices
I hope this will help you a bit more.
local sensorwu = 'Temp veranda via LAN' --name of the sensor that gets created when you add the WU device (and that contains multiple values like temperature, humidity, barometer etc)
local idx = 579 --idx of the virtual temperature sensor you created
if
then
sWeatherTemp, sWeatherHumidity, sWeatherPressure = otherdevices_svalues[sensorwu]:match("([^;]+);([^;]+);([^;]+)")
sWeatherTemp = tonumber(sWeatherTemp)
if
then
commandArray['UpdateDevice'] = idx .. '|0|' .. tostring(sWeatherTemp)
elseif
then
CurrentThread
Maybe updating the RFXCom firmware helps, see: viewtopic.php?f=28&t=12787
minionbob
@CurrentThread: Thanks. i put the EXT2 firmware on the RFXCOM and that solved it.
Super!
Super!
