No switches on Master visible Topic is solved
happyman
Post by happyman »
I try to work with two raspbarry boards. One is a 2b as master, the other is a 3b set as slave.
Both set with the same SD image and updated to the same Beta version.
Slave is using An USB zwave stick and an Piface board.
In the slave I created a user and set the devices.
In the log the connection is established. So far, so good.
The problem is that in the master only one switch is shown. The others are not.
Whatever I try, it only shows one.
Anyone an idea what goes wrong?
Derik
Re: No switches on Master visible
Post by Derik »
Allow new hardware/sensors on?
happyman
Post by happyman »
Derik wrote:Allow new hardware/sensors on?
It's not on, but released for 5min server all times.
Derik
Post by Derik »
Put it on.
And wait a longer time.
Switch in that time the device..
happyman
Post by happyman »
After 24hrs the switches are vissible :D
Users browsing this forum: willemd and 1 guest
