Reset/turn a switch/PIR off?
Calzor Suzay
Domoticz version: 4.9700
Post by Calzor Suzay »
Sometimes Domoticz doesn't always pick up a change in a door sensor or PIR etc.
I know this isn't Domoticz fault and down to the hardware and these things happen etc. I played with positioning etc. etc. but looking for an override so for example a magnetic door sensor says it's 'open' but quite clearly the door isn't and the I'm closed signal was never received or a PIR sensor that was detecting movement and Domoticz never sees the 'off' signal sent is there way to override this?
At the moment to counter this I tend to have go trigger the sensor so Domoticz sees the open then closed signal but I can't do this if I'm away etc. and the neighbours have brought my mail in or whatever.
annieoroberts00
Re: Reset/turn a switch/PIR off?
Post by annieoroberts00 »
Apparently because of the layout of the electrics in our house it wasn't really practical to rewire the kitchen light on its own - in the future when the rest of the house is done I guess it will be sorted out properly...I do have a new MCB, all beautifully labelled - these circuits are right next to each other in there so probably not as bad as it could be.
Calzor Suzay
Eh wrong thread?
bbqkees
Domoticz version: 4.1x
Post by bbqkees »
use a simple Blockly with the following logic:
IF SENSOR-A = ON, SET SENSOR-A = OFF after X seconds.
Calzor Suzay
I didn't realize you could directly effect the state of a PIR/Sensor etc. I'll try it.
