user have removed the Domoticz instance from MyDomoticz (deleted) - how can I restore it?
After login I see all the time "Enter your api data to your own Domoticz in order to use this service" - but the shown API key and password is still enabled in Domoticz.
Already tried:
- change password (at account and Domoticz settings)
- enable / disable multiple times at Domoticz
Maybe I need new API key - but how to get it for same account?
Already tried:
Thanks for any idea!
Weird... You should get a new instance id when your Domoticz connects again.
What's your old instance id?
It looks like my Domoticz (running on pi) has problems staying online if fiber modem resets (resetting the router doesn't affect stability/service).
I guess that when modem resets, I get some other IP address. Is there some workaround to this? Can I somehow reset domoticz if my external IP changes?
I guess some script could be written on pi that will monitor external IP, and then reset domoticz (or entire pi?) when external IP changes? Anyone that has already done this?
Raspberry Pi 2 B - MySensors (dimmers, switches, motion, temperature, lux, humidity sensors)
zWave (220v switches)
various 433 via RFLink
I have connected once as a shared user (??) (there was a hand below user icon in mydomoticz) and user name was completely different than my (it was MaciekK). But a system was offline (red user icon)...
MyDomoticz has a problem with uniqueness of Instance ID and security (in my opinion).
Is it possible to erase Instance ID from my domoticz?
If you click on the Instance ( the name of it, not the green/red icon) you will find a option to "Remove instance"
Raspberry PI 4 with RaZberry Controller 2016 ZWave+ and CC2531(zigbee)
Several IKEA devices/z-wave devices
I can't see Instance ID in MyDomoticz because by local domoticz is not registered in MyDomoticz (because of password / API key).
In MyDomoticz I have only option to see my API key and password / name change.
In MyDomoticz Dashboard instead of User icon I see only "Enter your api data to your own Domoticz in order to use this service".
Is it possible to remove Instance ID in local domoticz?
arcos wrote:I can't see Instance ID in MyDomoticz because by local domoticz is not registered in MyDomoticz (because of password / API key).
So your "MyDomoticz Instance ID:" on your local Domoticz is blank ?
You have tried to remove the API, password and then disable and enable the service?
I have tried to do everything (change the password, remove the password, recover password on mydomoticz, remove api key on local domoticz) - still the same error in log "PROXY: Authenticate result: wrong password for apikey/instanceid combination.":
My Instance ID on local domoticz is NOT empty and that is why I think that it's not unique and somebody else has the same ID.
I have to say that when I have created mydomoticz account everything was fine on the beginning. After while mydomoticz shows that domoticz is offline. After that I have deleted domoticz from mydomoticz service and created again - I have still this error.
arcos wrote:I have tried to do everything (change the password, remove the password, recover password on mydomoticz, remove api key on local domoticz) - still the same error in log "PROXY: Authenticate result: wrong password for apikey/instanceid combination.":
Could you PM me your API key?
I have the same problem as arcos is describing here.
Is there a solution for this?. Maybe its time to add a button to generate a new instance id in the domoticz web gui?
