domoticz install on orangepi does not start automaticly
nawikre
Post by nawikre »
Hi there,
i want to use a orangepi with domoticz. I have installed raspbian on the orangepi and used this install wiki everyhting is good, but it will not start automaticly. When i go to the ip adress it keeps saying Domoticz offline.
The only thing i am not sure about are these settings.
USERNAME=pi
DAEMON=/home/$USERNAME/domoticz/$NAME
DAEMON_ARGS="-daemon -www 8080"
The username for orangepi is orangepi, so i use DAEMON=/home/orangepi/domoticz/domoticz
then when i am finished i use this command
sudo service domoticz.sh start
then it shows nothing and just reveales a new line...
When i want to check the status of the install to see if it is running i use this command
sudo service domoticz.sh status
But again, it does nothing, it just shows a new line. When i try this on a raspberry pi it gives me some line where it states that domoticz is up and running.
I am no programmer, so i know there is a mistake somewhere....i just need to be pointed in the right direction.
Hope someone can help.
Iwan
georgesattali
Re: domoticz install on orangepi does not start automaticly
Post by georgesattali »
Hello Iwan,
1) the file you must edit is /etc/init.d/domoticz.sh
and not the copy in /home/pi/domoticz (or orangepi maybe).
2) where is located the executable domoticz ?
if this executable is in the /home/pi/domoticz then
USERNAME=pi
if this executable is in the /home/orangepi/domoticz then
USERNAME=orangepi
that way, you can let the line unchanged :
the orangepi seem a good alternative to the raspberry, are you happy with it ?
what are your impressiosn ?
Bye
GD
jannl
Domoticz version: 2022.2
Post by jannl »
And you can enable logging to debug the start of Domoticz. You may have an error of some kind.
georgesattali
I have read that raspberry images are compatible with orange pi.
you may try to put an image with dz already installed (http://sourceforge.net/projects/domoticz/files/) on an sd card (using Win32DiskImager), put the sd card in your orange pi, and boot and maybe - with some luck...
Bye,
GD
