RFlink might support Mi-light and other protocols soon :)
433Mhz opensource Receiver & Transmitter.
Stuntteam
Re: RFlink might support Mi-light and other protocols soon :)
Post by Stuntteam »
Yes, fully..
Larsja
Domoticz version: V2.3530
Post by Larsja »
What exactly is "2.4 Ghz, NRF24L01 with Milight wiring required"? What do i need to do with this? http://www.ebay.com/itm/310651702557
deennoo
Post by deennoo »
You need to follow this wiring instruction : http://www.nemcon.nl/blog2/wiring
This device works (got one), I use a 5v to 3.3v converter to power it from my méga + 10uf condo.
Actually rflink doesn't use the fully power of this device, maybe next time
http://domo-attitude.fr
burton666
Post by burton666 »
I don't understand, how do I pair/ control a mi-light bulb using only the domoticz gui? I have wired the nrf radio as the instructions .
Stuntteam
Post by Stuntteam »
Without remote control:
Go to: http://www.nemcon.nl/blog2/faq
and scroll down to
"how to pair Milight bulbs without the original Milight remote control in Domoticz?"
If you have a remote control:
you can pair bulbs as usual.. make sure auto accept new devices is turned on for some time and press the ON button for the zone you want to use on the remote control..RFLink will detect the remote control signal and tell Domoticz about it.. it will then show up in your device list.
burton666
Post by burton666 »
I only get "problems creating sensor" every time I try the commands.
deennoo
Post by deennoo »
Please enable allow new device on your domoticz parameters
Which Domoticz version have you ?
burton666
Post by burton666 »
I am using the latest beta of domoticz. I have checked the options to always allow all devices in the settings.
I have tried two different nrf radios and have checked the wireing several times.
Stuntteam
Post by Stuntteam »
Check the hardware tab.. is firmware listed as version 42?
burton666
Post by burton666 »
yes it is
burton666
Post by burton666 »
And I have my mi-light just a 1m away from the RF-link gateway and I have unpaired the lamp in advance using the android app
Stuntteam
Post by Stuntteam »
Range for sure is not an issue.
Check your PM..
Larsja
Post by Larsja »
deennoo wrote:You need to follow this wiring instruction : http://www.nemcon.nl/blog2/wiring
Ah, thanks :)
I have the RFLink shield from Nodo-Shop.nl so im guessing then its just plug and play, gotta see if i find some drawings.
deennoo
Post by deennoo »
Milight wiring is different from the nodo shield.
Larsja
Post by Larsja »
Blast!
Stuntteam
Post by Stuntteam »
Also, make sure you enable miglight after flasing the firmware..
burton666
Post by burton666 »
Where? in domoticz?
deennoo
Re: RE: Re: RFlink might support Mi-light and other protocols soon :)
Post by deennoo »
burton666 wrote:Where? in domoticz?
On RFLink loader who come with the R42 fw
burton666
Post by burton666 »
I tried flashing again using the loader from r42. I see the buttons to turn ON/OFF nodo + milight but they are greyed out before/during/ and after the flashing, I can't press anything other than "upload firmware"
deennoo
Post by deennoo »
Enable serail on rflink loader (i promise you will not create a black hole by try to press some button by your own)
