Did you follow the steps on https://www.domoticz.com/wiki/MyDomotic ... ng_started ?JoHi wrote:Hi all,
For me the same.
After login, there is the message:
"Enter your api data to your own Domoticz in order to use this service"
checked and double checked everything.
Joop.
MyDomoticz - Testers wanted!
- chimit
- Domoticz version: master
Re: Testers wanted!
Gravityz
- Domoticz version: 2025.1
Re: Testers wanted!
hello,
initially MyDomoticz worked fine but after a while it stops working.
the only way to get it to work is to go to Domoticz setup and change the settings(copy/paste api key, pasword) and save it again)
i do the same on the mydomoticz settings
it seems that it disables functionality after a long time of inactivity
assenzuid
Re: Testers wanted!
Looks like MyDomoticz is down?
- chimit
Re: Testers wanted!
Thanks for reporting. I restarted the service for now. Looks like a new issue.assenzuid wrote:Looks like MyDomoticz is down?
assenzuid
Re: Testers wanted!
Is it correct that I saw this morning (after several x refresh) a screen with a Commodore 64 emulator?chimit wrote:Thanks for reporting. I restarted the service for now. Looks like a new issue.assenzuid wrote:Looks like MyDomoticz is down?
- chimit
Re: Testers wanted!
I think that's what you get if you use the plain http port and the service is down. Not sure.
Gravityz
Re: Testers wanted!
Can we do something about mydomoticz loosing connection.
today it happened again
the only way to get it green again is to go to domoticz, cut/paste the api key and press save.
that way it reinitializes with mydomoticz, otherwise it stays red forever.
- chimit
Re: Testers wanted!
So far you seem the only one who reports this problem. A few hundred other users not. Maybe you can post some details about your setup to see into that. And some log lines will help.Gravityz wrote:Can we do something about mydomoticz loosing connection.
- Minglarn
- Domoticz version: v3.8153
Re: Testers wanted!
Add me to this too...
From the log...
From the log...
Clearing the api key and saving fixes this for another 15 min... But its seems that 15min is the limit.2016-05-24 20:45:51.290 PROXY: Authenticate result: success.
2016-05-24 21:02:11.340 Error: PROXY: Read failed, code = 335544539. Reconnecting: short read
2016-05-24 21:02:46.362 Error: PROXY: StartThread(): Exception: resolve: Host not found (authoritative)
“When you eliminate the impossible, whatever remains, however improbable, must be the truth.” -Spock in Star Trek VI
- chimit
Re: Testers wanted!
Thanks for these log lines. Seems a name server issue. Either within the domoticz code or external.Minglarn wrote:Add me to this too...
From the log...Skärmklipp.PNG2016-05-24 20:45:51.290 PROXY: Authenticate result: success.
Gravityz
Re: Testers wanted!
if you mean the dns
i use opendns 208.67.222.123 or 208.67.220.123
do not have any dns problems so far
Domoticz runs on a suynology NAS which uses the router as default gateway.
just a standard setup.
2016-05-23 13:43:00.893 Error: PROXY: Read failed, code = 335544539. Reconnecting: short read
2016-05-23 21:32:07.359 Error: PROXY: Read failed, code = 335544539. Reconnecting: short read
2016-05-24 03:35:08.165 Error: PROXY: timeout occurred, reconnecting
2016-05-24 03:35:08.186 Error: PROXY: Read failed, code = 125. Reconnecting: Operation canceled
2016-05-24 03:58:08.325 Error: PROXY: timeout occurred, reconnecting
2016-05-24 03:58:08.325 Error: PROXY: Read failed, code = 125. Reconnecting: Operation canceled
2016-05-24 03:58:23.368 Error: PROXY: StartThread(): Exception: resolve: Host not found (authoritative)
JulianBernhuber
Re: Testers wanted!
New to this Forum.
Are you still searching for Testers, if yes please contact me as I can not (since Users have to be active in the Forum bevore sending PM's).
Also I can maybe contribute to the project.
Cheers
Julian
New to this Forum.
Cheers
Julian
kkc1983
- Domoticz version: Stable
Re: Testers wanted!
Follow the steps in on this wiki page: http://domoticz.com/wiki/MyDomoticzJulianBernhuber wrote:Hi,
New to this Forum.
Cheers
Julian
JulianBernhuber
Re: Testers wanted!
Hi,kkc1983 wrote:Follow the steps in on this wiki page: http://domoticz.com/wiki/MyDomoticzJulianBernhuber wrote:Hi,
New to this Forum.
Cheers
Julian
First of all, Thanks for the great work!
I already did that, works great!
Since I would like to implement the service myself(run the service on my own server) I need access to the code.
Is there a possibility I could get access to code? Or could you publish the current status of MyDomoticz on https://github.com/domoticz/mydomoticz.
My team is kind of dependent on this part of Domoticz, if you can't publish yet, can you give me a timeframe in which it will be published/accessible?
If you guys need help, maybe we could cooperate and contribute to the project?
Cheers,
Julian
mirasp
- Domoticz version: 3.5877
Re: Testers wanted!
Hi, I'm testing remote access via MyDomoticz. Worked fine for a few days but since 19th June I can't access. See only "red" dashboard. Is it due ongoing development?
- chimit
Re: Testers wanted!
MyDomoticz should be online. Double check your settings if you have "enabled" checked. If yes, try to restart your Domoticz instance.mirasp wrote:Hi, I'm testing remote access via MyDomoticz. Worked fine for a few days but since 19th June I can't access. See only "red" dashboard. Is it due ongoing development?
If that doesn't succeed, PM me with your instance id or api key.
== Rene
mirasp
Re: RE: Re: Testers wanted!
Thanks, I will do that after workchimit wrote:MyDomoticz should be online. Double check your settings if you have "enabled" checked. If yes, try to restart your Domoticz instance.mirasp wrote:Hi, I'm testing remote access via MyDomoticz. Worked fine for a few days but since 19th June I can't access. See only "red" dashboard. Is it due ongoing development?
== Rene
JulianBernhuber
Re: Testers wanted!
Cheers,
Julian[/quote]
Thanks Chimit for your PM, but since the forum rules are broken I still can't send any PM's, regardless. I tried it all...
Please text me via [email protected]
Thanks,
Julian
Cheers,
Julian[/quote]
Thanks,
Julian
mirasp
It's working now but from time to time I see some errors in logs:mirasp wrote:Thanks, I will do that after workchimit wrote:MyDomoticz should be online. Double check your settings if you have "enabled" checked. If yes, try to restart your Domoticz instance.mirasp wrote:Hi, I'm testing remote access via MyDomoticz. Worked fine for a few days but since 19th June I can't access. See only "red" dashboard. Is it due ongoing development?
== Rene
2016-06-22 21:10:07.349 Error: PROXY: Read failed, code = 335544539. Reconnecting: short read
2016-06-22 21:36:55.090 Error: PROXY: Read failed, code = 335544539. Reconnecting: short read
- Varazir
Re: Testers wanted!
I'm too getting
I have added allowed IP address didn't help
EDIT:
I did this:
Removed the Instance and
disabled / enabled the service on the local box (didn't help)
Changed the autologin pass/user to the web protective info.
Now I got it to work.
The web login only accepted my MyDomoticz Password
2016-06-28 21:21:09.174 Error: PROXY: Read failed, code = 336130329. Reconnecting: decryption failed or bad record mac
2016-06-28 21:21:24.178 Error: PROXY: Read failed, code = 125. Reconnecting: Operation canceled
2016-06-28 21:21:39.182 Error: PROXY: Handshake failed, reconnecting: wrong version number
2016-06-28 21:21:54.184 Error: PROXY: Handshake failed, reconnecting: unexpected record
2016-06-28 21:22:09.189 Error: PROXY: Connect failed, reconnecting: Operation canceled
2016-06-28 21:22:24.192 Error: PROXY: Connect failed, reconnecting: Operation canceled
2016-06-28 21:22:39.196 Error: PROXY: Connect failed, reconnecting: Operation canceled
2016-06-28 21:22:54.199 Error: PROXY: Connect failed, reconnecting: Operation canceled
2016-06-28 21:23:09.203 Error: PROXY: Connect failed, reconnecting: Operation canceledEDIT:
I did this:
Raspberry PI 4 with RaZberry Controller 2016 ZWave+ and CC2531(zigbee)
Several IKEA devices/z-wave devices
