Hi there!
I bought some of these sensors and had a lot of problems to include them.
Tried the first one to include without luck. Resetted the sensor, also no luck.
So i tried the second one with the same result.
Googled a lot about that problem and only found 1 helping post.
Before you want to include you have to CLOSE THE SENSOR, that will help!
I don´t now why, but it´s working...
Oliver
Fibaro Door/Windowsensor FGK-101
- Egregius
- Domoticz version: v2024.7
Re: Fibaro Door/Windowsensor FGK-101
And how will you push the button if the cover is closed?
In my opinion it's only the tamper switch that needs to be closed for inclusion.
- robpow
- Domoticz version: Beta :)
Isn't the external tamper switch under the sensor identical to the button inside the casing? Either way, both are labelled TMP in the manual:
http://www.fibaro.com/files/instrukcje/ ... 21-v23.pdf
However, I'm pretty sure I kept the sensor flat on a table with the case open so that the external TMP was pushed in and then triple-clicked the internal button when I added my three sensors. Maybe there are many ways to skin this cat.
Matt
Matt
OCB73
- Domoticz version: 3.4834
I didnt´t tried it with external button pushed and then using the internal,
but i will try it with my next sensor and give a feedback.
I only tried internal or external tamper alone with open sensor and no luck.
Since i closed the sensor, external one is working fine for inclusion with triple-click.
Oliver
Oliver
