Dear all,
(I am quite new to domoticz so maybe I am asking the obvious).
Have a Vision doorlock with deadblolt and code-access: http://www.domotica-shop.nl/vision-deur ... 16412.html
I inluded it in the network, it is recognised.
But I cannot configure anything in 'Hardware'.
And in 'Devices', it is only recognised with name: 'Locked' and status: 'Closed' . It seems to me that this is the deadbolt.
But I cannot find the Codedisplay or anything to configure. The supplier doesn't know as well.
So I hope someone has experience with a lock like this, I'd like to know if the problem is in Domoticz or in the lock.
Thanks for your reply!
Vision doorlock with code - how to configure???
raym
Re: Vision doorlock with code - how to configure???
Hi. I recently bought a similar lock: the Vision ZM1701 (same as yours but without a handle). You will find the PIN code config in the OZW control panel but I cannot work out to set them.Eisbeer wrote: ...But I cannot find the Codedisplay or anything to configure. The supplier doesn't know as well.
In this link: https://github.com/OpenZWave/open-zwave/issues/657 it looks like the codes are stored in Ascii (although looks like hex?). Using the example in the link, I'd assume a PIN code of 1-1-1-1 would look like this: 0x61 0x61 0x61 0x61 0x00 0x00 0x00 0x00 0x00 0x00 but when I submit those digits, OZW saves them as: 0xc0 0xc2 0x04 0x94 0x98 0x7f 0x00 0x00 0x00 0x00
I don't get it
Can anyone shed some light on this please?
raym
I asked the same question on the OZW forum and it seems ASCII for "1" is "0x31". I have tried specifying the following string for PIN 1-1-1-1:
0x31 0x31 0x31 0x31 0x00 0x00 0x00 0x00 0x00 0x00
However, this still doesn't work.
Is there anyone here using Z-Wave locks with Domoticz that might know how to setup PIN codes for this device please?
Thanks.
Thanks.
stijnd
I have bought the same lock and have the same issue.
Did you find a way to set the codes? Currently I am using raspberry as a master.
raym
No luck, unfortunately. Latest response from openzwave (Justin) is below but I haven't found a solution yet:
https://github.com/OpenZWave/open-zwave ... t-17489419
stijnd
I have seen that the Vera Edge is supporting this lock.
Maybe I need to buy this and see if we can have it working.
raym
I believe *only* Vera supports it... which suggest there must be a way.
If you do go down that path and work out how the PINs are encoded, please share.
dannybloe
Did you manage to get it to work with Domoticz? Seems OpenZwave has support for it.
