Fibaro door sensor included as node, not visible in devices.
rf646
Hi, I have succesfully included my fibaro door and window sensors through the add node procedure. They do not appear in the device list afterwards. I have included other zwave devices before and they all showed up after adding the node.
Running the latest stable version of domoticz on a pi and using an Aeon Labs USB Z-Stick.
Any help is much appreciated.
Will try to add additional info later.
- mvveelen
Re: Fibaro door sensor included as node, not visible in devices.
They should appear as FIBARO System FGK101 Door Opening Sensor (if you have the same) after including them. Perhaps you might want to exclude them and include them again, one by one? Or reset the sensors and exclude / include them again?
rf646
Thanks for the suggestion. I have already tried excluding and including them and also resetting them and then including again. The weird thing is that the inclusion works fine, only they don't show up in devices afterwards. I've looked through al the devices without filter, but can't find them.
Thanks for any advice in advance.
- Plaagje
- Domoticz version: Latest
Keep trying, I had to include the door sensor several times before Domoticz included it succesfully
Sent from my Nexus 5X using Tapatalk
rf646
So it did include but did not show up in devices in your case?
- gizmocuz
did you try restarting domoticz ?
- Plaagje
Re: RE: Re: Fibaro door sensor included as node, not visible in devices.
I keep including it till is was a success sometimes I had to delete if it was not a successrf646 wrote:So it did include but did not show up in devices in your case?
rf646
I did try restarting domoticz a couple of times. That didn't work. I will try to add end remove a couple more times than I already have done before. I'll let you guys know if it works. Thanks so far for the suggestions.
BartSr
- Domoticz version: V2024.7
Allthough this thread is almost five years from now: faced almost same problem. Nodes can be seen but nothing in devicelist. I don"t see the problem has been solved from above messages.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
