Fibaro door sensor included as node, not visible in devices.
rf646
Post by rf646 »
Hi, I have succesfully included my fibaro door and window sensors through the add node procedure. They do not appear in the device list afterwards. I have included other zwave devices before and they all showed up after adding the node.
Running the latest stable version of domoticz on a pi and using an Aeon Labs USB Z-Stick.
Any help is much appreciated.
Will try to add additional info later.
rf646
Re: Fibaro door sensor included as node, not visible in devices.
Post by rf646 »
Anybody?
mvveelen
Post by mvveelen »
They should appear as FIBARO System FGK101 Door Opening Sensor (if you have the same) after including them. Perhaps you might want to exclude them and include them again, one by one? Or reset the sensors and exclude / include them again?
rf646
Post by rf646 »
Thanks for the suggestion. I have already tried excluding and including them and also resetting them and then including again. The weird thing is that the inclusion works fine, only they don't show up in devices afterwards. I've looked through al the devices without filter, but can't find them.
Thanks for any advice in advance.
Plaagje
Domoticz version: Latest
Post by Plaagje »
Keep trying, I had to include the door sensor several times before Domoticz included it succesfully
Sent from my Nexus 5X using Tapatalk
rf646
Post by rf646 »
So it did include but did not show up in devices in your case?
gizmocuz
Post by gizmocuz »
did you try restarting domoticz ?
Plaagje
Re: RE: Re: Fibaro door sensor included as node, not visible in devices.
Post by Plaagje »
rf646 wrote:So it did include but did not show up in devices in your case?
I keep including it till is was a success sometimes I had to delete if it was not a success
rf646
Post by rf646 »
I did try restarting domoticz a couple of times. That didn't work. I will try to add end remove a couple more times than I already have done before. I'll let you guys know if it works. Thanks so far for the suggestions.
BartSr
Domoticz version: V2024.7
Post by BartSr »
Allthough this thread is almost five years from now: faced almost same problem. Nodes can be seen but nothing in devicelist. I don"t see the problem has been solved from above messages.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
