Tried it again, take note for whomever has problems with this...even though my Qubino says it's a ZMNHBD1 (sticker on the device itself) it was added/recognised as a ZMNHBDx (check in your zwave hardware list) in Domoticz. So it was still taking the "faulty" xml file.Egregius wrote:Have you removed the endpoints line from the xml and so have 3 switches?
After replacing the ZMNHBDx.xml with the correct file, removing the endline and excluded and included the node (again) I can report it is working finally as it should! Indeed 3 switches are included once the process was done correctly.
Many thanks for your help guys!
Was already afraid I should have cancelled my order as I have two more Qubino's on the way
Thanks again!
P.
