Dear readers,
I've trying to include the Qubino Flush Shutter DC ZMNHOD1 but when I it is recognized as:
Qubino Unknown: type=0003, id=0053
There it is... Unknown. Don't get the specs or settings, can't use it right now.
Someone knows the answer?
Kohen
Synology NAS 412+, Aeotec stick V5, Aeotec recessed door sensor, Aeotec micro double smart switch, Fibaro Dimmer, iPad 2 with own 3d printed wall mount.
- bbqkees
- Domoticz version: 4.1x
Re: Qubino Flush Shutter DC ZMNHOD1
Your device is not in the OpenZwave list.
So you need to write your own config file or maybe you can ask qubino to to so.
They recently created many config files for OpenZwave.
Check the http://www.openzwave.com/ website for more info.
- Egregius
- Domoticz version: v2024.7
You could try adding this line to Config/manufacturer_specific.xml:
That line links the type/id to the config file of another flush shutter of Qubino. Could be that it works instantly with that (after exclude/include off course).
<Product type="0003" id="0053" name="ZMNHODx Flush Shutter" config="qubino/ZMNHCDx.xml"/>
- wolph
I've actually created a pull request to support this device: https://github.com/OpenZWave/open-zwave/pull/898
Having that said, Egregius his solution is 99% correct, it just lacks one tiny feature (parameter 86) which you probably won't miss.
