Qubino Flush Shutter DC ZMNHOD1
Kohen
Post by Kohen »
Dear readers,
I've trying to include the Qubino Flush Shutter DC ZMNHOD1 but when I it is recognized as:
Qubino Unknown: type=0003, id=0053
There it is... Unknown. Don't get the specs or settings, can't use it right now.
Someone knows the answer?
Synology NAS 412+, Aeotec stick V5, Aeotec recessed door sensor, Aeotec micro double smart switch, Fibaro Dimmer, iPad 2 with own 3d printed wall mount.
bbqkees
Domoticz version: 4.1x
Re: Qubino Flush Shutter DC ZMNHOD1
Post by bbqkees »
Your device is not in the OpenZwave list.
So you need to write your own config file or maybe you can ask qubino to to so.
They recently created many config files for OpenZwave.
Check the http://www.openzwave.com/ website for more info.
Egregius
Domoticz version: v2024.7
Post by Egregius »
You could try adding this line to Config/manufacturer_specific.xml:
<Product type="0003" id="0053" name="ZMNHODx Flush Shutter" config="qubino/ZMNHCDx.xml"/>
That line links the type/id to the config file of another flush shutter of Qubino. Could be that it works instantly with that (after exclude/include off course).
wolph
Post by wolph »
I've actually created a pull request to support this device: https://github.com/OpenZWave/open-zwave/pull/898
Having that said, Egregius his solution is 99% correct, it just lacks one tiny feature (parameter 86) which you probably won't miss.
