After building this simple node thats just a Arduino Mini Pro and a NRF24l01+ radio http://forum.mysensors.org/topic/3607/m ... sensors/22
I have managed to pair a mi-light RGBW as a on/off switch but have not been able to use the dimmer or colors. Would it be possible to integrate this someway. Every Arduino node serves as a repeater for NRF24l01+ when no bulbs are beeing controlled. And when a control-command is sent to any bulbs it switches the radio to control the bulbs then switches back.
So you can control unlimited number of bulbs, get great NRF24l01 coverage (=bulb-control coverage), easy to build as it is made of two components, you do not need any wifi-bridge and costs like 3$ to make.
Integrate controlling Mi-light/LimitlessLed without bridge.
- Domoticz version: LastBeta
Re: Integrate controlling Mi-light/LimitlessLed without bridge.
+1 for this.
The coverage with the default (excusez le mot) piece of crap bridges is horrible. Next to that I have had 3 bridges now who simply loose their wifi connectivity after a while and the 4 zone limit is ridiculous.
homebridge, rfxcom, zwave, nest, applamp, hue, debian, apple, mysensors, netatmo, fibaro, synology, foscam, otherz
Sorry for spamming several threads. But could it be so easy that someone only needs to add an option to be able to select a NRF24L01 USB-Gateway under the Mi-light-Hardware-options besides the IP/Port that the standard wifi gateway uses?
Re: RE: Re: Integrate controlling Mi-light/LimitlessLed without bridge.
I think you have to créateur it on domoticz github source.burton666 wrote:Sorry for spamming several threads. But could it be so easy that someone only needs to add an option to be able to select a NRF24L01 USB-Gateway under the Mi-light-Hardware-options besides the IP/Port that the standard wifi gateway uses?
On my side got 2 wifibridge, 1 since junary, 2nd since 1 week, i never get any wifi problème (freebox révolution)
Something can be done with RFLink...
http://domo-attitude.fr
