Integrate controlling Mi-light/LimitlessLed without bridge.
burton666
Post by burton666 »
After building this simple node thats just a Arduino Mini Pro and a NRF24l01+ radio http://forum.mysensors.org/topic/3607/m ... sensors/22
I have managed to pair a mi-light RGBW as a on/off switch but have not been able to use the dimmer or colors. Would it be possible to integrate this someway. Every Arduino node serves as a repeater for NRF24l01+ when no bulbs are beeing controlled. And when a control-command is sent to any bulbs it switches the radio to control the bulbs then switches back.
So you can control unlimited number of bulbs, get great NRF24l01 coverage (=bulb-control coverage), easy to build as it is made of two components, you do not need any wifi-bridge and costs like 3$ to make.
safi78
Domoticz version: LastBeta
Re: Integrate controlling Mi-light/LimitlessLed without bridge.
Post by safi78 »
+1 for this.
The coverage with the default (excusez le mot) piece of crap bridges is horrible. Next to that I have had 3 bridges now who simply loose their wifi connectivity after a while and the 4 zone limit is ridiculous.
homebridge, rfxcom, zwave, nest, applamp, hue, debian, apple, mysensors, netatmo, fibaro, synology, foscam, otherz
burton666
Post by burton666 »
Sorry for spamming several threads. But could it be so easy that someone only needs to add an option to be able to select a NRF24L01 USB-Gateway under the Mi-light-Hardware-options besides the IP/Port that the standard wifi gateway uses?
deennoo
Re: RE: Re: Integrate controlling Mi-light/LimitlessLed without bridge.
Post by deennoo »
burton666 wrote:Sorry for spamming several threads. But could it be so easy that someone only needs to add an option to be able to select a NRF24L01 USB-Gateway under the Mi-light-Hardware-options besides the IP/Port that the standard wifi gateway uses?
I think you have to créateur it on domoticz github source.
On my side got 2 wifibridge, 1 since junary, 2nd since 1 week, i never get any wifi problème (freebox révolution)
Something can be done with RFLink...
http://domo-attitude.fr
