How manage settings timers during the holidays ?
- warp
If I want a virtual switch to do settings holidays or normal on the dashboard ? can i use lua ? or other ?
Raspberry 2B:RaZberry Z-Wave+:Edimax EW-7811UN:Huawei E220 3G
4xQubino ZMNHCA2
Everspring SE812 & ST812
Mcohome MH-S411 & MH-S412
2xAEON LABS ZW-100
2xFibaro FGSD-002:Fibaro FGFS-101:Fibaro FGS-221 & KLF-050
4xQubino ZMNHCA2
2xAEON LABS ZW-100
- G3rard
- Target OS: -
- Domoticz version: No
Re: How manage settings timers during the holidays ?
I would like this possibility as well.
So to be able to switch the timer plan (Settings, Other) from default to Holiday and vice versa. See picture below (scroll down for setting).
Is it possible to do this via a script?
Not using Domoticz anymore
- G3rard
- Target OS: -
Does anyone know if this is possible or not?
I want to be able to set Domoticz in holiday mode (changed timers, receive notifications etc) with one virtual switch.
- G3rard
- Target OS: -
I saw in this topic viewtopic.php?f=23&t=6446&p=42360&hilit ... lan#p42360 that it's currently not possible to set this via a script.
- G3rard
- Target OS: -
Thanks to @dnwppo it is now possible to switch between Default and Holiday timer groups using a virtual switch.
Add the following in the On Action of the switch to activate the Holiday timer:
In the Off Action to activate the Default timer:
See more information on https://github.com/domoticz/domoticz/co ... d2ec61cb8a.
http://127.0.0.1:8084/json.htm?type=command¶m=setactivetimerplan&ActiveTimerPlan=1Code: Select all
http://127.0.0.1:8084/json.htm?type=command¶m=setactivetimerplan&ActiveTimerPlan=0Not using Domoticz anymore
- warp
Is it possible to test the state in LUA script ?
4xQubino ZMNHCA2
2xAEON LABS ZW-100
4xQubino ZMNHCA2
2xAEON LABS ZW-100
