Avidsen doorbell (Hornbach)
gdekeijzer
Domoticz version: 3.8637
Post by gdekeijzer »
Does anybody know if the Avidsen doorbell will work on RFXCOM?
It uses the 433mhz channel.
- VM running Debian with Domoticz 3.8637
- RFXtrx443E FW1006
- 2 x YouLess FW2.1 Analog energy and gasmeter
- 3 x Impuls, 3 x Action-brand
- 2 x Cresto Temp
- 3 x MiLight with WiFi-box v3
gdekeijzer
Re: Avidsen doorbell (Hornbach)
These are the codes and the device itself
- RFXtrx443E FW1006
- 2 x Cresto Temp
b_weijenberg
Post by b_weijenberg »
This device is not in the supported list, see chapter 2 of the RFXtrx User Guide.
However, you can try with RFXmngr and enable only Lighting4 or with an RFXtrx433E try also with only ByronSX enabled.
RFX-433, RFX-433EMC, RFX-868
gdekeijzer
Ok, got some output in RFXmgr
chimed 2 times:
0913001500000000D580
Packettype = Lighting4
subtype = PT2262
Sequence nbr = 21
Code = 000000
S1- S24 = 0000 0000 0000 0000 0000 0000
Pulse = 213 usec
Signal level = 8
0913001600000000D880
subtype = PT2262
Sequence nbr = 22
Code = 000000
Pulse = 216 usec
Signal level = 8
Now to create a lighting4 switch in Domoticz.
- RFXtrx443E FW1006
- 2 x Cresto Temp
b_weijenberg
I suppose the message cannot be used because a RF packet with all zeroes is received.
gdekeijzer
My thoughts exactly. However, a PT2262 device was suddenly in my unused devices list, around 300 times... :|
(ok, havent been there awhile, but )
I'm moving on ..
- RFXtrx443E FW1006
- 2 x Cresto Temp
