Error: RFLink: Unhandled switch command: SET_LEVEL=5 Topic is solved
BarryT
- Domoticz version: 2024.3
i have recieved a rflink yesterday, but it doesnt look like its working correctly?
2016-04-24 00:31:08.002 Error: RFLink: Unhandled switch command: SET_LEVEL=5
2016-04-24 00:31:09.301 Error: RFLink: Unhandled switch command: SET_LEVEL=5
2016-04-24 00:31:10.006 Error: RFLink: Unhandled switch command: SET_LEVEL=5
2016-04-24 00:31:11.382 Error: RFLink: Unhandled switch command: SET_LEVEL=5
2016-04-24 00:31:21.576 Error: RFLink: Unhandled switch command: SET_LEVEL=5
2016-04-24 00:31:22.210 Error: RFLink: Unhandled switch command: SET_LEVEL=6
2016-04-24 00:31:22.874 Error: RFLink: Unhandled switch command: SET_LEVEL=5
2016-04-24 00:31:57.917 Error: RFLink: Unhandled switch command: SET_LEVEL=5
2016-04-24 00:31:58.671 Error: RFLink: Unhandled switch command: SET_LEVEL=6
2016-04-24 00:31:59.350 Error: RFLink: Unhandled switch command: SET_LEVEL=5
2016-04-24 00:32:08.135 Error: RFLink: Unhandled switch command: SET_LEVEL=5
2016-04-24 00:32:08.861 Error: RFLink: Unhandled switch command: SET_LEVEL=6
2016-04-24 00:32:09.619 Error: RFLink: Unhandled switch command: SET_LEVEL=5
2016-04-24 00:32:10.314 Error: RFLink: Unhandled switch command: SET_LEVEL=5
2016-04-24 00:32:10.990 Error: RFLink: Unhandled switch command: SET_LEVEL=6
2016-04-24 00:32:11.760 Error: RFLink: Unhandled switch command: SET_LEVEL=5
There are no other devices added so far, its an empty domoticz started up with no new hardware allowed.
This really drives my crazy!
It is full of errors..
*Edit, ofcourse latest domoticz (beta) and latest rflink firmware.
Someone know whats going on here?
Thank you!
Thank you!
- Stuntteam
Re: Error: RFLink: Unhandled switch command: SET_LEVEL=5
What device would be causing that?
Maybe you can check with rflink loader what the output is..
BarryT
I really have no idea what i could be..Stuntteam wrote:What device would be causing that?
at the moment the problem is gone, so i guess it is only at evening when it is dark and my lights are on (sended trough rfxcom)..
for my lights i only use 5 kaku (dimmable) devices, and a lot on/off switches.
i will send the (loader) log tonight when the lights are on, and the error will be there again.
BarryT
Thnx Stuntteam..
It seems this is/was an bug in Domoticz, now waiting for the update
manjh
- Domoticz version: 2025.2
I am seeing a lot of these errors in the Domoticz log:
2016-05-05 22:32:44.781 Error: RFLink: Unhandled switch command: SET_LEVEL=255
Everything seems to be working just fine, but..... could this be caused by the same bug?
Hans
BarryT
Did you have domoticz updated to the latest version?
manjh
ah, no. Will do so. (Running a Win10 based Domoticz server, so updating is manual I guess...)
Hans
manjh
Brings me to a suggestion: I understand automatic update is a challenge, but could there be at least a warning if the Domoticz server is running an outdated version? A simple mail would be sufficient... or else an indication on the settings tab, showing the currently running and the latest available versions.manjh wrote:ah, no. Will do so. (Running a Win10 based Domoticz server, so updating is manual I guess...)
Hans
- gizmocuz
Web should get a notification after a few dates that there is an update when the login the web interface (not an application)
Also... what was the bug in domoticz ? As i am not aware of fixing an issue like this?? It looks like a script issue
manjh
Ah, could well be. I always start thinking of a mistake of my own, but since I am a long-time tester for a major big (blue) computer company, I usually find the bugs before someone else does.gizmocuz wrote:Web should get a notification after a few dates that there is an update when the login the web interface (not an application)
But I get this message without any reason, as far as I can see. No script of mine sets this level.....
Hans
BarryT
2 (beta) version ahead, and the messages are still there...
2016-05-12 21:29:05.608 Error: RFLink: Unhandled switch command: SET_LEVEL=5
2016-05-12 21:29:06.419 Error: RFLink: Unhandled switch command: SET_LEVEL=6
2016-05-12 21:29:07.144 Error: RFLink: Unhandled switch command: SET_LEVEL=7
2016-05-12 21:29:28.856 Error: RFLink: Unhandled switch command: SET_LEVEL=8
2016-05-12 21:29:29.576 Error: RFLink: Unhandled switch command: SET_LEVEL=7
2016-05-12 21:29:30.182 Error: RFLink: Unhandled switch command: SET_LEVEL=8
2016-05-12 21:29:41.883 Error: RFLink: Unhandled switch command: SET_LEVEL=7
2016-05-12 21:29:42.514 Error: RFLink: Unhandled switch command: SET_LEVEL=5
BarryT
I think it is not a script thing?gizmocuz wrote:Also... what was the bug in domoticz ? As i am not aware of fixing an issue like this?? It looks like a script issue
It has to do with the rflink and/or the domoticz supported hardware?
The only thing on that rpi is an irrigation system with 2 humidity/temp (ground) sensors and 2 water valves..
I did not added any other hardware in the RFLink, as well it doesnt look for any new hardware, as done in settings (do not look for new hardware).
Domoticz Ver:
5116 Beta
