Error: RFLink: Unhandled switch command: SET_LEVEL=5 Topic is solved
433Mhz opensource Receiver & Transmitter.
BarryT
Domoticz version: 2024.3
Post by BarryT »
i have recieved a rflink yesterday, but it doesnt look like its working correctly?
2016-04-24 00:31:08.002 Error: RFLink: Unhandled switch command: SET_LEVEL=5
2016-04-24 00:31:09.301 Error: RFLink: Unhandled switch command: SET_LEVEL=5
2016-04-24 00:31:10.006 Error: RFLink: Unhandled switch command: SET_LEVEL=5
2016-04-24 00:31:11.382 Error: RFLink: Unhandled switch command: SET_LEVEL=5
2016-04-24 00:31:21.576 Error: RFLink: Unhandled switch command: SET_LEVEL=5
2016-04-24 00:31:22.210 Error: RFLink: Unhandled switch command: SET_LEVEL=6
2016-04-24 00:31:22.874 Error: RFLink: Unhandled switch command: SET_LEVEL=5
2016-04-24 00:31:57.917 Error: RFLink: Unhandled switch command: SET_LEVEL=5
2016-04-24 00:31:58.671 Error: RFLink: Unhandled switch command: SET_LEVEL=6
2016-04-24 00:31:59.350 Error: RFLink: Unhandled switch command: SET_LEVEL=5
2016-04-24 00:32:08.135 Error: RFLink: Unhandled switch command: SET_LEVEL=5
2016-04-24 00:32:08.861 Error: RFLink: Unhandled switch command: SET_LEVEL=6
2016-04-24 00:32:09.619 Error: RFLink: Unhandled switch command: SET_LEVEL=5
2016-04-24 00:32:10.314 Error: RFLink: Unhandled switch command: SET_LEVEL=5
2016-04-24 00:32:10.990 Error: RFLink: Unhandled switch command: SET_LEVEL=6
2016-04-24 00:32:11.760 Error: RFLink: Unhandled switch command: SET_LEVEL=5
There are no other devices added so far, its an empty domoticz started up with no new hardware allowed.
This really drives my crazy!
It is full of errors..
*Edit, ofcourse latest domoticz (beta) and latest rflink firmware.
Someone know whats going on here?
Thank you!
Stuntteam
Re: Error: RFLink: Unhandled switch command: SET_LEVEL=5
Post by Stuntteam »
What device would be causing that?
Maybe you can check with rflink loader what the output is..
BarryT
Post by BarryT »
Stuntteam wrote:What device would be causing that?
I really have no idea what i could be..
at the moment the problem is gone, so i guess it is only at evening when it is dark and my lights are on (sended trough rfxcom)..
for my lights i only use 5 kaku (dimmable) devices, and a lot on/off switches.
i will send the (loader) log tonight when the lights are on, and the error will be there again.
BarryT
Post by BarryT »
Thnx Stuntteam..
It seems this is/was an bug in Domoticz, now waiting for the update :-)
manjh
Domoticz version: 2025.2
Post by manjh »
I am seeing a lot of these errors in the Domoticz log:
2016-05-05 22:32:44.781 Error: RFLink: Unhandled switch command: SET_LEVEL=255
Everything seems to be working just fine, but..... could this be caused by the same bug?
Hans
BarryT
Post by BarryT »
Did you have domoticz updated to the latest version?
manjh
Post by manjh »
ah, no. Will do so. (Running a Win10 based Domoticz server, so updating is manual I guess...)
Hans
manjh
Post by manjh »
manjh wrote:ah, no. Will do so. (Running a Win10 based Domoticz server, so updating is manual I guess...)
Brings me to a suggestion: I understand automatic update is a challenge, but could there be at least a warning if the Domoticz server is running an outdated version? A simple mail would be sufficient... or else an indication on the settings tab, showing the currently running and the latest available versions.
Hans
gizmocuz
Post by gizmocuz »
Web should get a notification after a few dates that there is an update when the login the web interface (not an application)
Also... what was the bug in domoticz ? As i am not aware of fixing an issue like this?? It looks like a script issue
manjh
Post by manjh »
gizmocuz wrote:Web should get a notification after a few dates that there is an update when the login the web interface (not an application)
Ah, could well be. I always start thinking of a mistake of my own, but since I am a long-time tester for a major big (blue) computer company, I usually find the bugs before someone else does.
But I get this message without any reason, as far as I can see. No script of mine sets this level.....
Hans
BarryT
Post by BarryT »
2 (beta) version ahead, and the messages are still there... :(
2016-05-12 21:29:05.608 Error: RFLink: Unhandled switch command: SET_LEVEL=5
2016-05-12 21:29:06.419 Error: RFLink: Unhandled switch command: SET_LEVEL=6
2016-05-12 21:29:07.144 Error: RFLink: Unhandled switch command: SET_LEVEL=7
2016-05-12 21:29:28.856 Error: RFLink: Unhandled switch command: SET_LEVEL=8
2016-05-12 21:29:29.576 Error: RFLink: Unhandled switch command: SET_LEVEL=7
2016-05-12 21:29:30.182 Error: RFLink: Unhandled switch command: SET_LEVEL=8
2016-05-12 21:29:41.883 Error: RFLink: Unhandled switch command: SET_LEVEL=7
2016-05-12 21:29:42.514 Error: RFLink: Unhandled switch command: SET_LEVEL=5
BarryT
Post by BarryT »
gizmocuz wrote:Also... what was the bug in domoticz ? As i am not aware of fixing an issue like this?? It looks like a script issue
I think it is not a script thing?
It has to do with the rflink and/or the domoticz supported hardware?
The only thing on that rpi is an irrigation system with 2 humidity/temp (ground) sensors and 2 water valves..
I did not added any other hardware in the RFLink, as well it doesnt look for any new hardware, as done in settings (do not look for new hardware).
Domoticz Ver:
5116 Beta
