Event using remote for security // need help
pecora
I was wondering why this blocky won't work. Has anyone a suggestion? The image has been attached...
- Schermafbeelding 2016-04-22 om 13.04.15.png (26.13 KiB) Viewed 985 times
georgesattali
Re: Event using remote for security // need help
why it doesn't work I'm not sure, maybe that's because blockly wants on or off in Set.
The block of the example sets RemoteHJ to a boolean value ( SecurityStatus=Armed Home ) which can be true or false, but blockly waits for On or Off.
you may have to transform it in 2 blocs to produce same effect (yeah bit ugly
if RemoteHJ=On and SecurityStatus=Armed Home then
DomoticSecurityPanel = On
if RemoteHJ=On and SecurityStatus # Armed Home then
DomoticSecurityPanel = Off
pecora
Thanks for the suggestion Georgesattali but this is not the solution. It will not work
This is the effect needed:
If remote = on
then domoticz sec panel = armed
If remote = on
