Event using remote for security // need help
pecora
Post by pecora »
I was wondering why this blocky won't work. Has anyone a suggestion? The image has been attached...
Schermafbeelding 2016-04-22 om 13.04.15.png (26.13 KiB) Viewed 992 times
georgesattali
Re: Event using remote for security // need help
Post by georgesattali »
why it doesn't work I'm not sure, maybe that's because blockly wants on or off in Set.
The block of the example sets RemoteHJ to a boolean value ( SecurityStatus=Armed Home ) which can be true or false, but blockly waits for On or Off.
you may have to transform it in 2 blocs to produce same effect (yeah bit ugly ;-)
if RemoteHJ=On and SecurityStatus=Armed Home then
DomoticSecurityPanel = On
if RemoteHJ=On and SecurityStatus # Armed Home then
DomoticSecurityPanel = Off
pecora
Post by pecora »
Thanks for the suggestion Georgesattali but this is not the solution. It will not work ;)
This is the effect needed:
If remote = on
then domoticz sec panel = armed
