[MyDomoAtHome] Support thread
ahmedadelhosni
Re: [MyDomoAtHome] Support thread
Post by ahmedadelhosni »
epierre wrote:@ahmedadelhosni what gives:
curl 'http://192.168.0.4:3002/devices'
anything in the logs ?
I have done the following if I understood well
pi@raspberrypi:~/domoticz $ curl 'http://192.168.0.4:3002/devices'
curl: (52) Empty reply from server
Nothing new in the same log file.
Is there any log file rather than usage.log ?
Is there a compiled version released before Friday ? as it was working on last Friday after those changes. I guess it was 0.1.17
Can you please provide the .deb to install and test ?
epierre
Post by epierre »
yes remove the coma before the }
"auth": null} <-- this one extra coma
ImperiHome & MyDomoAtHome on top of:
868.42Mhz - Vera Lite - Fibaro SS-101, S-211, K-101, FWP - Fortress SSA2
433Mhz - Cubie Domoticz + RFXtrx + Oregon || Foscam 9821W
2,4Ghz - Cubie MySensors Gateway + COV + TempHumidity + Pressure + WaterMeter
epierre
Post by epierre »
ahmedadelhosni wrote: Nothing new in the same log file.
I gues this will not help solve it.
best to do:
in one console:
sudo service mydomoathome stop
sudo -u www-data /usr/share/mydomoathome/bin/mydomoathome
in another console:
sudo curl http://ip:3002/system
sudo curl http://ip:3002/rooms
sudo curl http://ip:3002/devices
from this you should see if it breaks.
naitsirhc
Post by naitsirhc »
Unfortunatly I didn't succeed with the project, so I decided to update my complete SD card. with a total fresh Domoticz. It was quite easy to install Domoticz and restore my database (SDcard image). Unfortunatly the new image was based on Rasbian Jessie with a new NodeJS 4.4.3 and NPM. I was not be able to update the programs (NOOB), so I have to downgrade to Wheezy and start again :-(
I will keep you informed....
Und Tschjuß
gdekeijzer
Domoticz version: 3.8637
Post by gdekeijzer »
I'm installing new Domoticz setup on Ubuntu 14.04 LTS 64-bit to replace my Pi2.
Trying to install MyDomoAtHome gives an error when trying to install:
Setting up mydomoathome (0.1.29) ...
npm WARN package.json [email protected] No bin file found at ./bin/mydomoathome
npm ERR! Linux 4.2.0-27-generic
npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "--production"
npm ERR! node v4.4.3
npm ERR! npm  v2.15.3
npm ERR! path /home/domoticz/.npm/basic-auth
npm ERR! code EACCES
npm ERR! errno -13
npm ERR! syscall mkdir
Running the command as sudo and not as user:
sudo apt-get install MydomoAtHome
As per manual.
Any ideas?
Regards,
Gerwin
- VM running Debian with Domoticz 3.8637
- RFXtrx443E FW1006
- 2 x YouLess FW2.1 Analog energy and gasmeter
- 3 x Impuls, 3 x Action-brand
- 2 x Cresto Temp
- 3 x MiLight with WiFi-box v3
epierre
Post by epierre »
gdekeijzer wrote:Hello,
no, new to me, I'll have to investigate. There are few PI2 on ubuntu around but this is good news yet ;-)
gdekeijzer
Epierre,
I'm not installing on aan Pi.
I'm installing on a VM.
Verstuurd vanaf mijn SM-G935F met Tapatalk
- RFXtrx443E FW1006
- 2 x Cresto Temp
epierre
Post by epierre »
hello, how do you set up your VM ?
I'm searching for a way to automatize a pi for my deployemnts test, mostly on raspbian
epierre
Post by epierre »
@gdekeijzer I've removed the line but I'm interresting in knowing why, so please tell me more ;-)
@all check in the new conf you never have a coma before the closing } on anyline, it crashed, I've opened a bug to the library owner. You can see that by a 100% CPU and no connexion
gdekeijzer
epierre,
It seems to have insufficient rights to create a directory inside the ~/.npm directory
The apt-get is initiated with sudo.
It seems sudo npm is not such a happy combo for that matter (reading fora).
I'll check in to this and let you know any outcome
Regards,
Gerwin
- RFXtrx443E FW1006
- 2 x Cresto Temp
epierre
Post by epierre »
gdekeijzer wrote:epierre,
must be specific to vagrant, it installs as sudo but I manage files rights for user and root, so under normal conditions this should work -;)
is there a vagrant for PI existing ?
gdekeijzer
Quick and dirty, doing a chmod 777 ~/.npm does the job, but that just the workaround.
Working now.
- RFXtrx443E FW1006
- 2 x Cresto Temp
gdekeijzer
@epierre. As requested, i'm running a VM on vSphere6 host with USB passthrough. 2 core 2Gb VM running Ubuntu Server 14.04LTS 64-bit.
Running smoothly
- RFXtrx443E FW1006
- 2 x Cresto Temp
ahmedadelhosni
best to do:
in one console:
in another console:
At last I am happy to solve the problem :D
Thanks to your help, I found that it breakss in mdah.js in line 2193 due to error in handling the data variable.
for(var i = 0; i < data.result.length; i++)
data.result.length return : Cannot read property 'length' of undefined
I just did someworkarounds and now the mobile application is working.
Thanks for guidance.
ahmedadelhosni
looks like there is a new update to 0.1.32 and it is fixed.
Thanks for your efforts.
epierre
Post by epierre »
ahmedadelhosni wrote: At last I am happy to solve the problem :D
Can you give me more information where this breaks (I added many lines recently so it is not relevant without your version ;-)
Thanks !
emmanuel
naitsirhc
Post by naitsirhc »
hi,
The system is up n running again. I opened a port in the router and I can see the devices when I enter an http adres (http://something.no-ip.biz:3002)
Als http://omething.no-ip.biz/ is working
Is it possible to connect Imperihome to that adres ( to the normal http site), without the certificates and stuff? Then I'm up and running I could get me another RPI to fix he thing with the certificates
Und Tschjuß
epierre
Post by epierre »
yes you can, at least add a login/pass as below in your configuration
  "app_name": "MyDomoAtHome",
  "domo_path": "http://192.168.0.28:8080",
   "auth": {
        "username": "admin",
        "password": "admin"
   "domoticz": {
naitsirhc
Post by naitsirhc »
Wauw
It works lke a charm. I created a nice password. Now some VPN and MAC filtering next to it and it's OK.
Thanks epierre for your great support
Und Tschjuß
starfish001
Post by starfish001 »
Anyone know where the gateway pid file is located? Nothing in /run or /var/run I'd like to monitor with monit
Sent from my Nexus 6P using Tapatalk
