I have bought this one: http://www.aliexpress.com/item/Free-shi ... 25731.html
Domoticz register it as an Chuango.
The problem is that nothing happens when I'm triggering it. I don't really now what switch type I should set it as.
I have made an blockly event so that it should turn on an outlet and turn on a lamp. According to the log things happen and under switches it turns on and so do the outlet but nothing happens in the real world. If I manually press the icon on the detector it turns on and the lamp also turns on but when triggering the sensor nothing happens. Maybe it works sometimes.
Any ideas?
Door sensor
ottoangel
- Domoticz version: 3.4834
Door sensor
RFLink on a Raspberry Pi 2.
- Stuntteam
Re: Door sensor
It is a door contact. Normally you can set it as a contact.
However, it is important to check if the sensor sends 1 or 2 signals. With that I mean if it sends open and close as seperate signals or only sends an open signal.
ottoangel
Re: Door sensor
It seems to send just one signal so I have set 'off' with a 10 second delay.
ottoangel
Re: Door sensor
If I restart Domoticz it seems to work for a while. It also seems that I got lots of double devices.
Maybe it isn't better than this?
- Stuntteam
Re: Door sensor
See pm.
