Do anyone know if the Qubino Smart meter DIN is supported i Domoticz/OpenZwave?
Martin
Hello,lemoi wrote:need to make it yourself. I did. Would you like to help test it?
I would like to buy it too, have you solved it?mazgon wrote: ↑Wednesday 01 February 2017 11:11 I solved activating the polling. This way I have realtime data in the dashboard, but I still have not the correct data. For example the KWh are reported in KW, so I have wrong graphs. Is there some one that know how to solve the issue? I'm running the updated beta and is the same removing and afdding the node again.... so..... HELP ;P
No, no help from anyone.... so still unusable with domoticz. In home assistant installed with any issue....Andree wrote:I would like to buy it too, have you solved it?mazgon wrote: ↑Wednesday 01 February 2017 11:11 I solved activating the polling. This way I have realtime data in the dashboard, but I still have not the correct data. For example the KWh are reported in KW, so I have wrong graphs. Is there some one that know how to solve the issue? I'm running the updated beta and is the same removing and afdding the node again.... so..... HELP ;P
I use it with latest stable (& even previous one, with a modified open zwave xml device config file as it was missing features at the time). All metering reports are OK (configured for update if vary more than 5%, so it's rarely re-updated over 30s or 1mn) without enabling pooling.
I have it udated to the latest beta and the result i the same, so you have no issues with the stable release?lost wrote:I use it with latest stable (& even previous one, with a modified open zwave xml device config file as it was missing features at the time). All metering reports are OK (configured for update if vary more than 5%, so it's rarely re-updated over 30s or 1mn) without enabling pooling.
Only issue is with relay control from ozw: Status is updated back after a change too late for open z-wave (several seconds)... that is fooled & auto send back another command reversing previous one. I sent messages at the time with a script workaround to make it work...
I also use this module for offloading my hot water tank if power > 8kW (electricity provider limit at 9). Works as intended.
So this one (mostly) works with Domoticz. With old-stable, support was not very good (missing stuff I corrected & were integrated upstream), but at least since current stable it should be OK with the relay control restriction (I think this is Qubino's fault, Meter firmware should not need up to 7s to send back relay status update).
I had issues with previous stable & updated device xml description file used by ozw. No issues after this (only on relay control from domoticz that required an unclean, but functional, hack device script): I/V/W are reported in measures tab. Only cumulative stuff cannot be seen directly, you have to go in OZW control panel.
