Qubino smart meter
alveman
Qubino smart meter
Post by alveman »
Do anyone know if the Qubino Smart meter DIN is supported i Domoticz/OpenZwave?
Martin
joolz
Re: Qubino smart meter
Post by joolz »
Would also like to know this.
lemoi
Post by lemoi »
need to make it yourself. I did. Would you like to help test it?
mazgon
Post by mazgon »
lemoi wrote:need to make it yourself. I did. Would you like to help test it?
I'm interested too on this power meter (or another similar one), can you provide me some details? It will work completely with domoticz?
Thanks a lot.
Stefano
mazgon
Post by mazgon »
I have installed successfully the power meter, in the ozw control panel is reporting the right values, but not in domoticz, is there anyone that can help me? Is not clear to me how can I manage the units of measure and create custom graphs to keep under control the usage and the instant consumption....sorry I'm a newbie in this world....
catweazle0172
Post by catweazle0172 »
I do also have an Qubino smart meter but its only send one time the values to Domoticz when I reconnect it to the power.
What can we do to resolve this problem and retreive the right and up to date values?
Is it the OZW Config file or is it Domoticz?
mazgon
Post by mazgon »
I solved activating the polling. This way I have realtime data in the dashboard, but I still have not the correct data. For example the KWh are reported in KW, so I have wrong graphs. Is there some one that know how to solve the issue? I'm running the updated beta and is the same removing and afdding the node again.... so..... HELP ;P
Andree
Post by Andree »
mazgon wrote: Wednesday 01 February 2017 11:11 I solved activating the polling. This way I have realtime data in the dashboard, but I still have not the correct data. For example the KWh are reported in KW, so I have wrong graphs. Is there some one that know how to solve the issue? I'm running the updated beta and is the same removing and afdding the node again.... so..... HELP ;P
I would like to buy it too, have you solved it?
mazgon
Post by mazgon »
No, no help from anyone.... so still unusable with domoticz. In home assistant installed with any issue....
Inviato dal mio iPad utilizzando Tapatalk
lost
Post by lost »
mazgon wrote: Thursday 25 January 2018 7:39so still unusable with domoticz. In home assistant installed with any issue....
I use it with latest stable (& even previous one, with a modified open zwave xml device config file as it was missing features at the time). All metering reports are OK (configured for update if vary more than 5%, so it's rarely re-updated over 30s or 1mn) without enabling pooling.
Only issue is with relay control from ozw: Status is updated back after a change too late for open z-wave (several seconds)... that is fooled & auto send back another command reversing previous one. I sent messages at the time with a script workaround to make it work...
I also use this module for offloading my hot water tank if power > 8kW (electricity provider limit at 9). Works as intended.
So this one (mostly) works with Domoticz. With old-stable, support was not very good (missing stuff I corrected & were integrated upstream), but at least since current stable it should be OK with the relay control restriction (I think this is Qubino's fault, Meter firmware should not need up to 7s to send back relay status update).
Derik
Post by Derik »
When it is in this list:
http://www.openzwave.com/device-database
Or give the developers from ozw the output of your device and perhaps:
nice thing...
mazgon
Post by mazgon »
I have it udated to the latest beta and the result i the same, so you have no issues with the stable release?
lost
Post by lost »
mazgon wrote: Thursday 25 January 2018 19:22 I have it udated to the latest beta and the result i the same, so you have no issues with the stable release?
I had issues with previous stable & updated device xml description file used by ozw. No issues after this (only on relay control from domoticz that required an unclean, but functional, hack device script): I/V/W are reported in measures tab. Only cumulative stuff cannot be seen directly, you have to go in OZW control panel.
But this imo not Domoticz fault: These energy counters are reported as parameters! Not very clever from Qubino imo... But an issue I can work with as I only monitor this every 2 month when I receive my electricty bill & verify this almost match.
With current stable, working without xml modification as this was taken upstream.
