ttyacm: serial port keep changing on Synology after restart
gdusordet
Post by gdusordet »
hi,
I had to reset my Aeotec Z-Stick Gen5 contoller which is connected to my Synology server. Each time I am rebooting Synology, it keep changing the serial port from /dev/ttyacm0 to /dev/ttyacm1 or /dev/ttyacm1 to /dev/ttyacm0. Any idea how to prevent it from changing the serial port after a restart?
thanks
G
woody4165
Re: ttyacm: serial port keep changing on Synology after restart
Post by woody4165 »
Have you read the Wiki?
Don't know if applicable to Synology, but it's Linux, you can try this.
http://domoticz.com/wiki/PersistentUSBDevices
gdusordet
Post by gdusordet »
thanks but I could not make it work for Synology
gooxbe
Post by gooxbe »
Maybe if you want to use lsusb, you should install usbutils with ipkg.
Hope this helps (maybe a bit late but want people who have the same question to find an answer), I'm in the same process.
amwr
Post by amwr »
Same problem here. I had to change from the old stick to Gen5 and now the ttyACM keeps switching between 0 and 1. Have you found a solution for Synology?
Egregius
Domoticz version: v2024.7
Post by Egregius »
Is that with Jadahl's package?
amwr
Post by amwr »
Yes. The latest DSM6 stable release.
Another (related?) problem is that after each reboot of the Synology the driver fails. After disconnecting and reconnecting the stick it works again.
Egregius
Post by Egregius »
Strange, never seen this with my S2 stick. I'm planning a replacement, will monitor this topic
Maybe an idea to contact Jadahl to see wth he thinks of it?
teo1966
Domoticz version: 2025.1
Post by teo1966 »
gdusordet wrote: Sunday 10 April 2016 8:50 hi,
thanks
G
i have the same
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 11 (bullseye)
Release: 11
Codename: bullseye
