Action Promax
Action Promax
I recently bought the Promax switches at Action. I can't seem to get them to work with my RFXtrx433E.
I just checked with RFXmngr and the devices behave exactly as described here viewtopic.php?f=49&t=9972, but this thread is for rflink...
I read that there is a fix for rflink, so I'm wondering if there is a fix for the RFXtrx433E? Anyone who also bought them?
b_weijenberg
- Target OS: -
Re: Action Promax
The PROmax module has a dedicated protocol and RFXCOM is working on a solution.
RFX-433, RFX-433EMC, RFX-868
Re: Action Promax
Aha, good to know. Where did you get this info if I may ask?
- Treve
- Domoticz version: v4.11474
Action Promax
I believe B_ has short lines with the manufacturer.
- RFXtrx433E,
- AEON Labs ZW090 Z-Stick Gen5 EU
- Hue v2.1
- Raspberry Pi 3 Model B, Raspbian Stretch Full on USB-Stick.
- Domoticz 4.11474
Devices: KaKu, Z-Wave, Hue.
for testing:
Raspberry 4, 2GB, SSD
Domoticz 2022.1
Ikea Hub, Fyrtur curtain
- Hue v2.1
- Domoticz 4.11474
for testing:
Domoticz 2022.1
Re: Action Promax
I there any chance that version 251 of the firmware brings support?
- Moppersmurf
- Domoticz version: Lat.Beta
Re: Action Promax
No, not in version 251.
FW release 433_95/195/251 06-02-2016
OWL CM180 ID improved
Maverick ET-733 added
Maverick ET-732 ID added (Type2 & Ext only)
Alecto WS1700/3500/4500 negative temp corrected
Viking 02813 added
WS1200 updated
ARC & Lighting4 can be enabled both (ARC/BBSB has priority)
Lighting4 improved
New PCR800 added
ASP blind motors added (Type1 & Type2 only)
Avantek added (Ext only)
Viking 02813 added
WS1200 updated
Lighting4 improved
New PCR800 added
cobra045
- Domoticz version: 3.4834
Re: Action Promax
For everyone who follows this.
Firmware changes in versions 433_1001
– Firmware type Ext2 released
– Firmware version numbering is changed
– Firmware Type displayed in response message
– IT protocol PROmax, FA500S, FA500WD, FA500DSS added (Ext2)
– Auriol Z31055B-TX sensor added (Ext2)
– WS1200 battery low indicator added
– Chuango, Eminent security sensors added:
– decoded as Lighting4 in Type1, Type2 and Ext
– decoded as X10 in Ext2
– Confexx blind motor added (Ext2)
jvilly
- Domoticz version: V.3.4834
Re: Action Promax
By having PROmax being mentioned in that list means that it is work in progress or does it mean it is implemented?
I just updated to this firmware, still I can not make it work. I could do something wrong here of course. But the remote is visible with both ARC and AC, but switching it on and off, does not work. I have the Promax 75006.14 RC50075
Raspberry PI 3 / Domoticz / RFXCOM433E / KAKU / Promax
b_weijenberg
- Target OS: -
Re: Action Promax
Ext2 firmware has the IT protocol for PROmax On/Off modules and FA500 On/Off and dimmer modules.
Domoticz has also the IT On/Off and IT Dimmer device implemented.
The remote transmits 3 protocols: ARC, AC and IT as Lighting4. ARC and AC can be used in Domoticz as IT receive is not implemented in the RFXtrx.
In Domoticz create manually an IT On/Off module and select a random ID and unit code (different from 0)
Put the module in learning mode,
Push the Test button in Domoticz or transmit an On command to add this Domoticz "remote" in the module. (up to 5 remotes can be added)
Note:
To remove a remote from a module, put the module in learning mode and transmit an Off command.
To remove all remote from a module, put the module in learning mode and transmit an All Off command.
Unit code 0 of the Domoticz IT device transmits an All On or All Off command.
Note:
cobra045
Re: Action Promax
I got it working
Thanks for the super support of RFXCOM by B Weijenberg
Cobra045
Cobra045
- screenshot_14.png (13.88 KiB) Viewed 9819 times
- screenshot_13.png (8.48 KiB) Viewed 9819 times
jvilly
Re: Action Promax
Owww yes! It works, thanks a lot people!
deejayd
Re: Action Promax
ive tryed it but it did not work ... need help if i learn the switch i can see it go on and off but if i manually turn in off in domoticz it does nothing
jvilly
Re: Action Promax
Try to make a manual switch (left side) instead of the learn option (right side). If the PROmax have been linked to the remote, switch the wall plug on then pull it out, plug it back in and press OFF on the remote, this will unlink your remote. Also the Led starts blinking which means it is available for pairing. Then quickly add the switch as per above, press 'Test' button and Domoticz sends out a signal to the wall plug and it works (in my case).
cobra045
Re: Action Promax
First install the firmware RFXtrx433_Ext2_1001.hex Or newer
If the PROmax have been linked to the remote, switch the wall plug on then pull it out, plug it back in and press OFF on the remote, this will unlink your remote. (thanks jvilly)
(1) Create a manual button (left side)
(2) Set Type to IT
(3) Make ID to 01 and 02 (Use not 00 and 00) otherwise you can use any code
(4) Set Unit Code 1 or 2 or 3 ..........
Now do not use the remote control
(5) Set the switching unit into the wall socket, the LED will blink, and push quickly the test button, before the flashing stops.
(6) Add device
If your the unit accidentally unplugged
Then this is not a problem. Place the unit (connect) the LED flashes again
Press the switch 2 times and the unit will work again with the same code
(2) Set Type to IT
(6) Add device
deejayd
Re: Action Promax
i have a rfxtrx433e is that a problem should i install the rfxtrx433 ext 2 or the rfxtrx433e ext 2 ?
deejayd
Re: Action Promax
nvm it worked thx action cobra
cobra045
Re: Action Promax
If you look in the log file you will see an error message when switching the switch.deejayd wrote:i have a rfxtrx433e is that a problem should i install the rfxtrx433 ext 2 or the rfxtrx433e ext 2 ?
What are the consequences I do not know this.
I tested this with both firmware the release 1001 from rfxtrx433e ext and the rfxtrx433e ext2
Cobra045
Ruben
- Domoticz version: latest
Re: Action Promax
Thanks for the conversation above. Problem is I cant select the type 'IT'. How can i ad this?
Thanks.
Ruben
Thanks.
Ruben
cobra045
Re: Action Promax
1) You do not use RFXtrx433E from RFXCOMRuben wrote:Hello,
Thanks.
Ruben
2) You do not use the firmware RFXtrx433_Ext2_1001.hex
3) select IT
Cobra045
cobra045
Re: Action Promax
b_weijenberg wrote:
Note:
How do I send a Unit code 0 of the Domoticz IT device transmits an All On or All Off from Domoticz ??
Cobra045
